when will we see 1000rwhp out of these hi HP porsches?
#211
Scott,
Matts car is on a 300 shot now and should make 800-850rwhp now and weighs about 3200-3300 with him in it. He went a 10.1 @ 144 with the clutch going bad in 2nd. http://www.vobra.org/vids/bonesawclutch.wmv that should be the link to the pass. The car runs 10.55 on motor with a best mph of 132. The car is pretty wicked and sounds basically stock with the cutouts closed.
#213
Is 68 pages covering 5 years of work enough info for you?
https://www.6speedonline.com/forums/...&highlight=cjv
#214
#215
LOL...the only way your pre 2K Chevy will 'implode' will be from the amount of gas you decide to dump in that poor little V8...
#216
Wooohooo!!! I'll be home in about 7 hours or so. I found out that we are indeed going out of town this weekend for mothers day so everything will have to wait till next weekend. Normally I'd just stay home from our ranch, but it is mothers day so .. yeah I'm basically volunteered into going.
Now if anyone wants to head up there and race the RZR or my 400EX they are more than welcome to lol!
#217
We lost alot of pics because photobucket closed. I have all the pics but way too much work to repost. The basics are Spanish case which was shuffle pinned and bow tailed, 80.4 mm crank w/ 2.0" journals and NASCAR oval bearings, Pauter titaniun rods, 105.7 mm steel liners and pistons, custom designed pistons with 9.6-1 compression, piston domes are ceramic coated, piston skirts are fricton coated, pistons are built for valve lift, Custom designed single lobe intake and exhaust cams with harmonic distortion eliminated, GT3 Cup heads with ceramic coated combustion chambers and exhaust ports, all ports were slightly ported to have a matched 360 cfm @ 25 psi, heads and liners were double o-ringed, custom head and case studs, custom designed and built three way springs that are heat repellant coated, custom titanium springs, custom designed and produced head gaskets, Inconnel valves which were ceramic and friction coated, GT1 three index oil pump, custom studs, heads will be e beam spot welded, 1100 cc injectors, World Cup plenum from 90 mm throttle body to heads, programable wet nitrous nozzles.
I'm sure some things were forgotten .......... but most was mentioned. Todd Knighten will be doing the tuning. The power will pretty much be limited by the turbo's and boost used. Motor is designed for a max of 2.4 bar, however 1.1 to 1.3 is about all we really need if we want any real longevity.
#218
#219
It is in between Madisonville and Centerville. We only have 54 acres but our good friend has 1000 or so acres that backs up to ours. So lots of space to 4 wheel and shoot stuff LOL. I haven't shot my ar15 in months so I cannot wait.
#220
Powell... Do you do any long range work with your 15 or a good old bolt action? Tim
#221
It is actually a m4a2 newer rifle. My good friend has a semi automatic from the 70s or 60s. My dad wants to get a good ol m1 carbine like my uncle use to bring up there.
We have lots of wild hogs up there that our game warden has okd the getting rid of. They destroy the creek beds and stuff.
#222
Interesting.....
Consider the dyno-glory if videoing the HP/TQ spike to "roughly" 3000 WHP/WTQ which would last for a pico-second. Then the added glory of seeing the PLASMA at the tuner's shop spattered with oil and perhaps a couple of twisted rods in the near nano-seconds to follow. I mean THEN you'd REALLY have "had" the highest HP Porsche on 6Speed. You could even run an alcohol/water injection system to "optimize" the destruction. If all you want is to be DYNO-KING then let's see him do it.
#223
Darkclaw13,
We lost alot of pics because photobucket closed. I have all the pics but way too much work to repost. The basics are Spanish case which was shuffle pinned and bow tailed, 80.4 mm crank w/ 2.0" journals and NASCAR oval bearings, Pauter titaniun rods, 105.7 mm steel liners and pistons, custom designed pistons with 9.6-1 compression, piston domes are ceramic coated, piston skirts are fricton coated, pistons are built for valve lift, Custom designed single lobe cams with harmonic distortion eliminated, GT3 Cup heads with ceramic coated combustion chambers and exhaust ports, all ports were slightly ported to have a matched 360 cfm @ 25 psi, heads and liners were double o-ringed, custom head and case studs, custom designed and built three way springs that are heat repellant coated, custom titanium springs, custom designed and produced head gaskets, Inconnel valves which were ceramic and friction coated, GT1 three index oil pump, custom studs, heads will be e beam spot welded, 1100 cc injectors, World Cup plenum from 90 mm throttle body to heads, programable wet nitrous nozzles.
#224
The good news is S Car Go Racing has in their possession all the internal parts, Protomotive has in their possession all the external parts and ERP has in there possession all the handling related parts. There is nothing left to do but assemble all the parts.
#225
Well fantastic.
