k24/18g vs Garretts
#121
Sorry, I thought fwhp meant four wheel hp, lol.
Yes, you will have to pay an extra 3 K for programming, but the power to cost ratio is still a relative bargain.
Edit: Kato, the only caveat is that these turbos are not quicker spooling. They have more lag w/ concomitant more power up top. If you want quicker spooling turbos then GT 28's are what you want. But that would be a LOT of money for the adaptive hardware. I would not go w/ K24/18's for autox.
Anybody else have a recommendation for me? Should I try the 16/24 hybrids with my current EVO K24 programming?
#122
Kato,
Talk to Tom kerr about the k24/18G on the track. I don't track, but I do have the k24/18G and they are very responsive. At the RPM's you would be utilizing at the track, I think you would be in the power band at all times and have a lot more up top than with a 16/24. I went from K16/24's to K24/18G's and do not notice any difference in lag, in fact my K24/18G's seem less laggy than the 16/24 hybrids and from my observations, offer a lot more power everywhere in the power band. They are an awesome turbo and I think you would be thrilled with them.
#123
As far as linear and smooth power delivery goes... well that has more to do with a custom tuner rather then a type of turbo you go with... or at least the ones mentions....
markski
2001 996TT 3.6L and stock ECU
#124
very interesting thread, i have stage 4 set up too. while it runs great, i always want more.
couple questions for the experts out there.
current set up, k24's, europipe exhaust, b&b headers, diverter valves, giac programming, evo wastegates, pss9 susp, fikse 18" profiles, pccb gen ii
i do drive my car every day, also do 6 or 7 roadcourse events a year.
will k24/18g ruin a daily driver?
can i keep my giac program, or will i need new software too?
sorry for the redundant questions, but it is a little confusing.
thanks to all for any info.
bob
bob
#127
I just drove a turbo S last weekend. First Time I've every been in a car with K24s. I've been using GT28s for about 5 years. I could not believe how LINEAR the K24s are. Like the car was naturally aspirated. Absolutely no turbo surge what so ever. If LINEAR is what you want, LINEAR is what you have. Get a stage 4 EVOMS program, port and coat your headers and you're done!
#128
I agree that they delivery is very linear right now (for a turbo car)... I'm not necessarily unhappy with the setup, I'm just looking for the next (minor) step that might yield me a bit quicker spooling and a bit more low/midrange push...
I'm very happy with the car so far, just seeing what else is within reach!
#129
Sorry to bump an old thread. My Mercedes CL600 uses K24's per its OEM setup. With my current modifications I regularly see 1.27+ BAR (18.5lbs) I currently make 555wrhp and 750rwtq. I have spoken to Protomotive about the k24/18g upgrade. My question is, do they upgrade the compressor wheel from the IHI 18g turbo or do they use the housing as well? The reason i ask is I am EXTREMELY space limited within my engine bay and have no room for physically larger turbos. Thanks for your help!
#130
How is it going bro? I would think that Todd should be able to answer this question. You should email him. Either way there is probably a solution for a turbo upgrade for your car. Can you eliminate anything in the engine bay to make room?
#131
Todd could answer any questions you have.
#132
hey frank, all is well, just trying to squeeze a bit more out of my current platform. The frame rails on all V12tt platform have to be widened for the stock turbos, theres just no room. Fueling becomes an issue as well. Im trying to move more air, obviously, but keep it as "oem" as possible. If youve been following VRP's 65 upgrade they add remote mount turbos and im not trying to go that route, I like to move as move as much air as possible in the current turbo housing. No one is doing this with my platform so I need to gain as much knowledge as I can before moving forward. Wide band 02 is going in next week to keep track if AFR's
04-28-2022 12:38 AM
dkfx
04-21-2016 01:58 PM
