Blown 6 Intercooler install
Old 05-25-2008, 06:18 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
Please excuse my lack of knowledge as I'm new to the 996tt (I've had mine about a week now). When I had my 930 I had a Koklen intercooler. The Koklen, in my 930, was huge compared to the stock. What is the difference between all of these intercoolers? It appears that they're all the same size. Thanks.....
  #32
Old 05-25-2008, 11:41 PM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
The EVOMS intercooler is much thicker and a more efficient bar-and-plate core design with better end tanks and much bigger outlets.
  #33
Old 05-25-2008, 11:54 PM
ReeknHavic's Avatar
I see, I didn't notice that it was thicker from the pictures. Thanks for explaining that for me.
  #34
Old 07-21-2008, 06:44 PM
ZIP22's Avatar
ZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond repute
Anyone know how to get a hold of Blown 6 outside of calling or email? They still haven't refunded my money!
  #35
Old 07-21-2008, 07:21 PM
kcphuah's Avatar
kcphuah is infamous around these partskcphuah is infamous around these parts
EG, did you buy this on the group buy? I bought mines through kilrgt ( Paul ) group buy. At first, I have waited quite a bit for it and I was not getting responses from Blown6, so I have email paul and ask for help. Paul has helped me and stayed on top of it and I have eventually got it after probably a 3 weeks waiting time. Perhaps you can pm him. Hopefully this will help.
  #36
Old 07-21-2008, 07:45 PM
ZIP22's Avatar
Hi kcphuah, yes, I bought them through the groupbuy. Thanks for the advice...I'll ping kilrgt.
  #37
Old 10-21-2008, 05:02 PM
ZIP22's Avatar
Still no refund from B6 after all this time. A fellow 6speeder has offered a hand to help me out with this ordeal with Michael of Blown 6.
  #38
Old 10-21-2008, 05:52 PM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
That's terrible. I almost bought a set of B6 IC's, but after waiting 3-4 months for shipping, I told them to forget it. I ended up buying a set of EVOMS IC's and couldn't be happier.
Someone should forward them a link to this thread. That might expedite the process???
  #39
Old 10-22-2008, 04:16 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
What about the hoses of the Evoms intercoolers?i saw from the pictures that they do not pair with the oem fittings...Is that right?What did you do about it?
  #40
Old 10-22-2008, 06:46 AM
ZIP22's Avatar
I paired the EVO ICs with the EVO MS silicone hoses that use a lip for a secure fit and the included genuine hose clamps to them locked down at high boost.
  #41
Old 10-24-2008, 05:40 PM
sharkster's Avatar
Good thinking! Secure them nice and tightly... It's no fun if they pop off under high-pressure and you have to remove the bumper again
  #42
Old 10-24-2008, 09:42 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
Zip22's style of installation is the way to go - the B6's as shipped are pretty restrictive compared to the EVOMS. I modified my B6's to make them equivilent to the EVO or perhaps a hair better from a flow standpoint, by cutting off the OEM style fittings and welding on 70mm aluminum tubing. This is a cost efficient mod to the B6's and is very easily done for between $100-$200 in welding fees. Here is a picture:
And here is an example of the difference in air passage - on the left is our 70mm intake kit with 70mm Y-Pipe / 70mm silicon hose, which demonstrates how the flow is enhanced by the elimination of the OEM fittings and on the right is a blown 6 IC fitting, which is the same as the OEM Y-Pipe fitting (these fittings are the most restictive part of the intake track and occur pre IC / post IC and Pre Y-Pipe for a total of 3 restrictive points). You can see by these pictures how much better a 70mm system and the EVOMS IC's will flow, but in order to take full advantage, you must replace the Y-Pipe, as well or you still have the restriction entering the Y-Pipe:
  #43
Old 11-06-2008, 04:59 PM
ZIP22's Avatar
Good news! After over 6 months Anthony of Blown6 came through and sent my refund check! Wooohooo!!!
Thank you Anthony!
Just ordered John's Speetech 700 as a reward! :-)
  #44
Old 11-06-2008, 06:32 PM
josh@iautohaus's Avatar
josh@iautohaus is a jewel in the roughjosh@iautohaus is a jewel in the roughjosh@iautohaus is a jewel in the rough
Wow that is horrible customer service. I have never bought anything from them but after hearing this I will never.
  #45
Old 11-06-2008, 10:02 PM
Prche951's Avatar
yup, same here. That is one of my upgrades this winter and I am staying away. I know UMW is working on making a set and Evoms has theirs.
Quick Reply: Blown 6 Intercooler install
