Almost There, New Symptoms. Won't Boost All The Way
#31
No. Not really. Does anyone have pictures to test this?
#32
1 end goes into the boost hose
1 end gets a "bike" valve screwed into it. (highlighted in the picture)
1 end gets the boost gauge screwed into it.
#34
You can get 90%+ of the stuff at home depot. I had to go to an industrial supply store to get a couple of things. 1. a couple of reducer fittings for the "T" and 2. the actual air-valve-thing. (Looks like for a bike tire, but is threaded where it attaches to the "T"
BTW, my boost tested was copied from BigBadBen's design.
#37
by teal im guessing you mean the pressure tester.
Last symptom. It seems by 2-3k RPM sometimes i here like a honking.... sometimes it happens, sometimes it doesnt. still doesn't boost all the way.
Any ideas?
Any ideas?
#38
Have you replaced your diverter valves? They typically "honk" when going bad.
#39
I believe I stated that I did indeed change out my DV with Forge but in case I didn't, Yes. My DV's were replaced sometime last year.
#40
The reasons DV's honk when going bad is because you get a hole in a rubber diaphragm that boosted air blows through. The air being forced through the rubber and making it slap against itself and whistle causes the "honking". Think of it kind of like the way a whoopie cushion makes its noise.
This reafirms my belief that you've got a boost leak somewhere. The boosted air escaping through something rubber is what's causing your "honking".
#43
Just because you have newer forged DV's doesn't mean its not the problem. Depending on the ones you have they need to be lubed.Its metal sliding on metal, who knows something could be stuck in there causing one to be stuck open.....Its worth having a look when your doing your F-hose.Most come apart so you can clean them up and lube them.
#44
