installed gt2 wing but need some help lol
i installed the gt2 add on wing , yesterday , i poped the old one off in like 5 min , then put the new one one , tottal time 10 min or so .
problem, i hit the button once,to lower the wing ,, it goes down like half way .... then i have to hit it once more. like it has two stages or something, fo it to go down all the way .... BUT , soon as it gets to the bottom , the one side goes down first and then the other side follows , in other words at the very bottom it goes down lopsided...
How do i fix this ? its annoying.
I recall someone say you have to loosen both side of the lift shocks and shake them up so they sought of reset themselves...? adjust themselves for the larger wing.. Im sure you can find it in the search menu
I had the same problem when I installed my tech-art type 1, mine was going up all the way both sides but not going down on one side. I pushed it down manually a few times and un installed the wing the installed it again and it works perfect every time, its been on for 3 or 4 months with no issues...Not sure why it happened but it works now.
I haven't tried the shaking thing, but after experiencing the same problem you describe above, I tightened only two of the three mounting bolts and lightly hand tightened the third (on each side). Worked for me.
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-20-2015 02:37 PM
