What would be the Best mods to get for $3000?
Old 05-14-2008, 08:53 PM
microboby's Avatar
microboby is infamous around these parts
Smile What would be the Best mods to get for $3000?
I just got a 2003 996 TT Seal Gray with 40,000 miles the car is 100% stock and I would like to upgrade a little without spending a lot of $$$ , I thought 3K would take me there so if anyone here has some advice It would be very appreciated.
Old 05-14-2008, 08:59 PM
acf's Avatar
acf
acf is offline
acf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to behold
used europipe!
Old 05-14-2008, 09:08 PM
MoeMonney's Avatar
MoeMonney is infamous around these parts
REVO software, they're a site sponsor and great.
www.revotechnik.com
Old 05-14-2008, 09:09 PM
spoonito's Avatar
spoonito is infamous around these parts
Ecu?
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Do a ECU flash first, about 2k, very noticeable power gain.
Old 05-14-2008, 09:14 PM
microboby's Avatar
ECU sounds about right , what is the most used brand out there?? I would only do exhaust if it has HP gains , not interested on Loud or Exotic Sounds without HP increase
Thanks for the replies
Old 05-14-2008, 09:18 PM
MoeMonney's Avatar
Te mande un PM Bernie. checalo, y te recomiendo el escape de titanio de Oakley Design.
Old 05-14-2008, 11:38 PM
microboby's Avatar
Would this FVD kit be a good buy??
996 Turbo Level 1 (490HP / 542LBF FT)
FVD 996 100 51 $1,657
Kit includes:
Sport Motronic DME exch., Sport Air Filter
Genuine:
Engine - 6Cyl. Boxer Twin-Turbo
Capacity - 3600ccm
Compression ratio - 9,4:1
Max. Power - 309kW (420HP) @ 6000rpm
Max. Torque - 560Nm (413lbf ft) @ 3500-4500rpm
Max. Speed - 305km/h
Max. RPM - 6750rpm
Acceleration 0-100km/h - 4.2s
Tuning:
Max. Power - 360kW (490HP) @ 6000rpm
Max. Torque - 735Nm (542lbf ft) @ 4000rpm
Max. Speed - 318km/h
Max. RPM - 7000rpm
Acceleration 0-100km/h - 3.9s
Old 05-15-2008, 12:26 AM
CarNerd's Avatar
CarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant future
GIAC or Softronic
Old 05-15-2008, 12:39 AM
sid350's Avatar
sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !
Softronic seems to be the way to go.
https://www.6speedonline.com/forums/...ight=softronic
Old 05-15-2008, 12:44 AM
willcoxmd's Avatar
willcoxmd is infamous around these partswillcoxmd is infamous around these parts
If you want to wake up your car, I would flash the ecu and find a used exhaust. On the other hand, you could upgrade the suspension with some new coilovers and lower the car. The car will look and handle better.
Old 05-15-2008, 04:48 AM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
Note:
Get software you can upgrade with your other hardware upgrades (credit)...check that first....say you get a LWFW and the car begins to stall more....software can fix that....make sure the "tune" you have can be upgraded to allow for this kind of thing. Some can. Some cannot.
Get BOV's if you get an ECU.
ECU for me meant a new clutch within 48 hours...my tuner's code makes a TON of torque...so be warned....a clutch is NOT cheap (labor)...I went with a LWFW while there. It was a more expensive net mod than I had planned for, but in the end, I am way ahead.......so an exhaust is perhaps a "safer" first mod....
Exhaust: if not rich($), search on the "modified stock exhaust" thread...TJW mod. I had it and it was about 50% of the way to a good exhaust. Down the road, get an exhaust and BOV's....
Old 05-15-2008, 05:28 AM
Speedshaq's Avatar
Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !
+ 1
Old 05-15-2008, 06:05 AM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
up it a couple hundred and get EPL's k16/24 kit. On stock exhaust thats 490awhp on a mustang.
S
Old 05-15-2008, 07:05 AM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
I'd get a flash, and a used exhaust if you have any $$ left over. I would stick with a tuner that offer upgradeability with their flashes, otherwise you will end up spending money twice for software.
From what I have heard, I'd stay away from Revo as a tuner. Once they flash your ECU or give you trial software, you won't be able to use any other tuner's software.
Quick Reply: What would be the Best mods to get for $3000?
