gt3076r's on stock bottem end
how many people, if any are running gt3076r on stock bottom end. If you are running these turbos, can you list what else you have done and if there are any dyno sheets you can post.
ie: what software/tuner, fuel,intake,exhaust etc etc.
I am running softronic ECU and GT3071s. I have run a decent amount of boost, but it all falls down to the 16psi or so marker due to some problem, even though it will spike 20psi at the beginning.
drop what you doing and listen to me.. trust me you will be one of the fastest Pcars ... period.
MArkski
2001 996TT 3.6L and stock ECU
Consider that they ALL RUN STRONG until they break. I think that since the Doctor (Imagine Auto) will do the upgraded rods for a GREAT PRICE it beats the !%$@~$ out of finding out the hard way and then having a $35K problem since last I hear there's no "core refund" on bent rods and once a block has been windowed. I take this post back ENTIRELY is all you're doing is running a GT700-ish kit and ONLY running the pump gas program and ONLY running the car on the street. Then you're probably ONLY putting around 525/525 TQ/HP to the tires. Honestly, for the extra $10K rods seem like VERY cheap insurance.
I was considering the marginal cost while everything else was being done. I did not ask Dr. Kaspar what his standalone rate would be, but note that because of his "process" whereby he doesn't charge you for splitting the cases, he'd be the way to go for this very important upgrade. Thanks Dr. Jitsu for clarifying on PX.
Ur asking for way too much... its a different hot side so unless someone makes one for mass production it will never happen.
