What tires to get?
Originally posted by damon@tirerack
Yep, go PS2. N spec in front, XL rating in the rear.
Weird, it is, but with Tire Rack, Discount Tire and other places, they do not say that.
Also, I noticed on your link that the 225/30/18's are NOT N rated however. It's backwards of what I've found elsewhere.
XL's may help control abuse to the outer edge of the tire, but in return, you give up some grip. That's the problem with the XL.
Having a ultra stiff sidewall is not necessarily a good thing. You need a little bend before it breaks.
It's all too confusing. Well, I just got the PS2's installed today. N or XL, I can't feel the difference yet without an AB test.
They do seem to be quieter than the pzeros. But then again, they're new. Will see if they stay hush after 5k.
I have to say that of all the max-perf tires, the PS2 is the most hohum looking one. Dull looking sidewall and tread design.
Looks like something from costco's. Regular PS looks better.
I just went through the gruesome process of looking for some new shoes for the beast. After much consideration, it came down to the PS2's which everyone is suggesting, and the new Toyo's T1-s. For some reason not too many people really use this tire, but woah!! it is an amazing tire! I know not many care, but the tread design, I feel looks better than the PS2's. Unfortunately, they do not sell this tire at many stores, because Toyo does not give distribution to a lot of places, or something like that, but if you are interested, post back and I will send you a link and a number to a guy who can give you a good deal. Also, they are much cheaper than the PS2's, an added bonus. But if money is no concern, PS2's are the way to go!
Collin, I don't know if you're 'screwed', but personally, I wouldn't want XL's on my car. I am pretty convinced that the PS2 is a better tire than the PS Ribs, but I also think that the XL takes away some performance on the tire. I do not think the PS2 XLs are going to be any better than the PS Ribs that are both N approved by Porsche.
Until Porsche officially N rates the PS2's for the Turbo, I'm staying clear.
I recommended T1-S's before, but I just realized that the fronts are only W-rated (i.e. fit for speeds up to 168MPH). Also, the rear tires closest fit would be a 295/35-18 with an Overall diameter of 26" which is about 1.1" too tall in the back.
Either way, they are not right for our cars.
- KJ
- KJ
