What tires to get?
#91
Originally posted by Scott in H-town
Colin, for understeer, you have it backwards. Your way will give you more understeer.
Inflating a tire more (to a certain point) gives it more grip. So inflating the front would give more grip in the front and thus less understeer right?
- KJ
#92
Depends on your starting point I guess, but the stock pressures are too high, so from stock pressures as a starting point, you lose traction by adding air. (this is from my personal experience)
#93
Scott, I track at least once a month and up to 4 times a month and not necessarily at the same track so shipping is not an option (yes, I am a little addicted)
I'm probably going to drive there on them or get a little trailer made to hitch to my car to just carry wheels.
#94
Originally posted by KJM3
I'm pretty sure if Colin inflates the front tires more (up to a point), he should be reducing understeer.
- KJ
- KJ
Oversteer can also be induced by increasing the rear slip angle or by reducing rear tire pressure a bit. I can avoid over inflating/deflating either by doing a bit to both front and rear.
I can start with a cold pressure a few degrees below the stock pressures so I don't end up in the extreme zones.
This is the oldest trick in the book without resorting to expensive suspension mods.
WheelB
991 Turbo Vendor Classifieds
07-23-2018 09:37 PM
WheelB
09-03-2015 10:26 AM
