helmet for drivers ed events, any suggestions>>>
any recommendations for snell m or sa, rated 2000 or 2005. any good vendor sources would be appreciated. thanks in advance.
mike
mike
I would suggest you find a local shop that carries Arai, Bell, Simpson etc..so you can get a good fit...also depends if you are going to get serious enough to want a neck restraint at some point...then get one that is Hans compatible or already has the Hans posts installed...also get one that is compatible with the type of seat you have (determine the layback angle of your seat)....in lieu of that try CDOC, Saferacer, Summit Racing, Bell, Simpson....they all carry good helmets
adnanm3
11-22-2023 02:43 AM
jaehoppa
10-22-2015 09:17 PM
