Understeer dilemma
Understeer dilemma
So after a hard track day last week and after reading many posts here, I sat pondering my cars shortcomings. One of which I see mentioned is the tendency for the car to push in the corners. I want to try and correct that as much as possible. A couple of caveats though; I chose the Pss9 coil overs knowing that I will compromise on the track for comfort on the street. I have them set at full stiff in the back and 2 notches down from stiff in the front. As a daily driver car, I didnt want to go the moton/JAC/etc route so going stiffer is out of the question being that I live in pothole ridden NY/metro area. I do have H&R bars set in the middle position of the 3 positions and havn't fiddled with them yet, so I can probably move that in one notch. And I have neg 1 degree camber, again, only because of street use. Is this just inherent in the car or will take allot to coax more over steer into the car. Any suggestions would be appreciated.
Either more negative camber on front wheels and/or tighten up the rear bar. I'm currently running full tight on the rear H&R adjustable bar and full loose in the front. Be sure not to have any preload on the bars. Good luck.
How would I know if I have any preload on the bars?
Must have adjustable drop-links. Adjust both ends (droplinks) to eliminate any preload on the bar from side to side. Bar should be neutral to avoid any torsion on either end. This should be done on a flat surface with driver in the car.
