One Turbo Smoking (what is the prob?)
Old 06-05-2008 | 04:46 PM
Staff@RPM's Avatar
Staff@RPM is infamous around these parts
Hi...Has your battery been out or dead? has car been sitting long. Do you have a 5bar FPR? As Joe said black = rich/ fuel and blueish = oil burning.. Tim
Old 06-05-2008 | 04:47 PM
heavychevy's Avatar
Dangit, I dont have time to get new plugs before my track day on saturday.
Old 06-05-2008 | 04:48 PM
heavychevy's Avatar
Yeah, my car sits for weeks at a time. I actually unhook the battery when I get out because it's an oddyssey and I didnt have a battery tender until today. Probably has sat for the last month or so. You think it will burn off?
Old 06-05-2008 | 04:56 PM
nicegsxr's Avatar
nicegsxr is infamous around these parts
you are running rich...
Old 06-05-2008 | 05:01 PM
heavychevy's Avatar
So then a nice weekend at the track should remedy that then huh?
Old 06-05-2008 | 05:31 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Originally Posted by Seal Grey Matte
Because each side exhausts a bank of 3 cylinders. If you have a dead plug in one of the passenger side cylinders, you aren't burning the fuel in that cylinder and you would only see that on the exhaust side where that cylinder is located.
Exactly!
Old 06-05-2008 | 05:35 PM
joetwint's Avatar
Probably not if its a bad plug.5K miles on the track is way too long between changes.Turbo motors eat plugs.
Old 06-05-2008 | 05:41 PM
Staff@RPM's Avatar
Hi.. If you take a hard drive and it is still the same, then change your plugs. After you reconnect the battery on cars with 60lbs and up injectors or 5 bar FPR's the ECU has to relearn the cold start maps. Tim
Old 06-10-2008 | 07:35 AM
heavychevy's Avatar
False alarm,thank goodness.
While I was removing the AWD, I had began to remove my straight pipes to put my PSI back on because of the noise restrictions at Barber. Well I eventually decided against it and put the straight pipes back on (which BTW didnt cause any problems with noise), but got sidetracked and forgot to put the Lambda sensors back on one side.
So I put them back on, and the smoke went away within a few seconds of starting her up, then at the track this weekend got a CEL. So I figured I must have put them on backwards, so I switched them (in 100*, DOH!!!!!) and the CEL went away.
So the moral of the story is: If you are switching to RWD only to end up switching back, and disconnect your catless exhaust in the process onlyto see black smoke coming out of one side after you have put it back on........
Check your lambda sensors.
Old 06-10-2008 | 01:34 PM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
Wait a second - you went to AWD? So what's the verdict now (did you do it the "correct" way?)?
Old 06-10-2008 | 04:05 PM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
Wow....a lot of work. Glad to hear it was not a major (expensive) engine issue.
Hope all is well!!!
JB
Old 06-10-2008 | 06:01 PM
heavychevy's Avatar
See other post on the topic.
04-28-2022 12:38 AM
COBB Tuning
01-29-2022 09:42 AM
The_Ruski_Driver
10-25-2015 08:40 PM
Quick Reply: One Turbo Smoking (what is the prob?)
