One Turbo Smoking (what is the prob?)
Old 06-05-2008 | 09:07 AM
heavychevy's Avatar
This came like very all of a sudden but one of my Turbos has a light trail of blackish smoke coming out of it under idle. It hasnt happened at all until the other day. I hadnt driven it for a few weeks then the smoke came.
I tried driving it for a while 15 minutes or so to see if it would go away, but it's still present.
Is my turbo failing? I have straight pipes, and it's one side only.
Old 06-05-2008 | 09:27 AM
vividracing's Avatar
if the turbo was bad you would see white/blue smoke from oil going past it and burning out the exhaust I would think. That is usually what we see on the Garretts if they were to blow a seal.
Old 06-05-2008 | 09:40 AM
heavychevy's Avatar
Yeah, it's definitely not white/blue and it's only on one side, and the car drives fine. What else could it be? It's a very light trail of black smoke, only visible at idle.
Old 06-05-2008 | 09:48 AM
I just might not be qualified for this one!
Bad cat, exhaust leak, no Vivid sticker... are you making normal boost? does it sputter? does the car sound ok. Take a short video and youtube it for us to see.
Old 06-05-2008 | 09:58 AM
heavychevy's Avatar
No cats, I guess an exhaust leak is possible, so is no vivid sticker, we'll have to get that remedied.
The car is sputtering a tad at light throttl occasionally. Could the plugs do that?
Old 06-05-2008 | 10:08 AM
Exhaust leak would not have black smoke though. Theoretically, you have an exhaust leak as you have straight pipes out of the turbo! Something possible with the turbo. I would do this, remove that right side turbo, make sure the impeller and all is good. Change your oil too. start there.
PM me your address and shirt size.
If your plugs are fouled that could be it too, what plugs do you have in there, how many miles?
Old 06-05-2008 | 10:22 AM
colorinc's Avatar
colorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond repute
plug? or injector?
Old 06-05-2008 | 11:36 AM
Bill in Atlanta's Avatar
Bill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud of
Done Blowed Up
Replace with 997 GT2
Old 06-05-2008 | 11:40 AM
mdd's Avatar
mdd
mdd is infamous around these parts
If it's sputtering and blowing black smoke, how can it not throw a CEL and error codes? Is your CEL burned out? Have you checked codes?
Old 06-05-2008 | 11:51 AM
MiniDHinkle's Avatar
Originally Posted by Bill in Atlanta
Done Blowed Up
Agreed.
Come on, Dez.
Old 06-05-2008 | 11:59 AM
Speedshaq's Avatar
Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !
Originally Posted by vividracing
Bad cat, exhaust leak, no Vivid sticker....
Old 06-05-2008 | 12:00 PM
y996t's Avatar
y996t is infamous around these partsy996t is infamous around these parts
you should check the spark plugs on the side if it has oil on it you need to rebuild the motor or take off the header on that side and look in to the exhaust ports to see if it has oil in it and if it do you do to rebuild or if there is no oil then you need to replace the check vavle on top the turbo
Old 06-05-2008 | 04:15 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Black smoke=Fuel or rich condition.......Blue smoke = burnt oil
Good thing is black smoke is the one I would be less worried about and is probably a bad plug,injector or other less expensive fix.Any codes?How many miles on plugs?
Old 06-05-2008 | 04:23 PM
heavychevy's Avatar
Why would the smoke only exit one side of the exhaust though???????????
I have quiet a bit of miles on the plugs, like 5k, majority on the track.
Old 06-05-2008 | 04:31 PM
Seal Grey Matte's Avatar
Seal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to behold
Because each side exhausts a bank of 3 cylinders. If you have a dead plug in one of the passenger side cylinders, you aren't burning the fuel in that cylinder and you would only see that on the exhaust side where that cylinder is located.
Quick Reply: One Turbo Smoking (what is the prob?)
