New High Flow Silicone Intercooler Pipe in the Works
Been working on this for a while. This will be an upgraded intercooler pipe kit. We are finishing the intake pipe which splits off to the 2 high flow silicone hoses. These replace the factory ones which are restrictive. Will keep you up to date. Should retail for about $1250 for the kit with intake pipe.
![](http://www.agency-power.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=155&g2_serialNumber=2)
Here is a picture of the Gemballa one
![](http://www.gemballa.com/gemballa_images/MTQ6MTE6MDMtMjAwNzExMDY=/OTIwMTQ6MTE6MDM=.jpg)
Here is the picture of the one currently in my car
![](http://www.vividracing.com/forums/gallery/files/5/5/4/3/intakeducthose7.jpg)
At same time (before you go into mass production) you might want to check hoses for the Tiptronic model as the area that passes through alongside the driveshafts are a lot tighter compared to manual, just a thought Dan
Good point.
Dan,
Could you considerer to offer Ceramic Coating in the Intake (Y) Pipe?
That will prevent to transfer engine heat to the Intake (Y) Pipe and feed with cooler temperatures the 2 long Silicone pipes
![Wink](https://www.6speedonline.com/forums/images/smilies/wink.gif)
I would say that most all cars could benefit from this at any level because of the restrictiveness of the stock plastic pipes. On the reverse, those that are running the stock pipes on cars with more then 500AWHP are losing out because that power needs more air flow to continue to climb.
oddjob142
08-19-2015 12:27 PM
ECS Tuning - VW
08-19-2015 08:58 AM
