Wheel bearings out at 20K?!
Old 06-11-2008 | 07:46 PM
greg911's Avatar
greg911 is infamous around these parts
I track my car a lot and had developed bad brake vibrations that no one could figure out until I finally replaced bearings and hubs. Now their are no vibrations or shudder and the brakes are rock solid on the track. I kept blaming rotors for the longest time and turned out to be bad bearings.
Old 06-11-2008 | 07:52 PM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
Originally Posted by heavychevy
So if I dont look, and have straight pipes, then I'll never notice? And therefore never have to change them?
Sounds like this is a quiet epidemic. I'm sure if there are this many here, then there have to be tons more out there that are still driving around with them.
What are the long term affects? What will a complete failure do? I have an aftermarket warranty, I wonder if they'll cover it (of course they have no clue I track.
Wheel will fly off.........lol.......
Actually the bearing would probably blow apart and the wheel would start flopping around held in by the axel until the entire mess came apart.
The hard part is that you need to remove the brakes and unhook your axel to see/feel if they are really bad. I noticed no deflection at all in the rears, just the slightest rough feel when rotated,and yet when taken apart they were absoloute TRASH. If they are making any noise at all,change them. The new bearings had a different (maybe improved) seal. I believe the failure is mostly due to dirt/water/dust contaminating the bearing. The bearing itself is a hell for stout design, but if any crap gets in there it's going to start to go. I think I will check them every 20K from now on.
Old 06-11-2008 | 08:55 PM
TT Surgeon's Avatar
My 996 c4s had it at 49k miles.
Old 06-12-2008 | 10:58 AM
CarNerd's Avatar
CarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant future
Did you upgrade to something other than OEM bearings?
Old 06-12-2008 | 11:56 AM
DERBOOST's Avatar
As far as I know there is no upgrade, just a slight change from 2001 till now, the old bearings had rubber/delrin seals. the new had a steel/rubber seal on one side,I assume to hold up better when dust,rocks etc hit it. It could also just be a manufacturing change over the years, who knows ???
Old 06-12-2008 | 04:55 PM
heavychevy's Avatar
So is there a chance any of the later model 996 TT's have the newer bearings? And has anyone checked the lifespan of the newer bearings vs the old?
And lastly, of all the 996 TT's has there ever been a catastophic bearing failure?
I think these are the most pressing questions than to have everyone running amuck looking for bad bearings.
Old 06-12-2008 | 04:59 PM
justinmm2's Avatar
justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !
How would you describe the sound that is supposedly symptomatic? I've been hearing some strange noises lately, wondering if this could be it... Hoping my ears are just playing tricks on me, though.
Old 06-12-2008 | 09:40 PM
DERBOOST's Avatar
The best I can describe it is that it sounds just like tire/road noise inside the car.
Go to deserted parking lot, speed up to 30-40 or so, pop in neutral and kill the motor, do a "S" turn back and forth, if noise goes away/changes they are most likely shot. The noise should change when you load/unload the bearing.
Old 06-17-2008 | 10:58 AM
itacud's Avatar
itacud is a jewel in the roughitacud is a jewel in the roughitacud is a jewel in the roughitacud is a jewel in the rough
Hmmm.... I've been blaming my tires (and roads, and anything else) for the deafening noise inside my cabin. I guess I'll be doing some parking lot tests now!
Old 06-17-2008 | 01:46 PM
Bill W's Avatar
Bill W is infamous around these parts
I thought my wifes brakes were bad once and started taking the thing apart. Once I got the caliper off the rotor fell on the ground because the bearing had completly fallen apart.
Even though your car only has 20k miles just remember that it is hard on moving parts to sit for extended periods of time, your car is still 6 years old.
Old 06-26-2008 | 09:09 AM
DRMitchell's Avatar
DRMitchell is infamous around these parts
What is the life expectancy range for wheel bearings on the Turbo?
04-28-2022 12:38 AM
Zero911
08-24-2015 06:51 PM
su_maverick
08-21-2015 07:14 PM
Quick Reply: Wheel bearings out at 20K?!
