1st time @ the 1/4 w/ the 996tt
Tough car to launch, got 2 runs in and could not get out of the hole on either of them, with a 2.09 60ft the car went 11.9 @ 125.0 mph....... I am running factory K24's, w/ exhaust, BMC filter and flash also Stage III clutchmasters clutch (might have been a little tricky for me)
I know the car is capable of a much better 1/4 mile time, my 60' is pathetic. I am just curious how the 125 MPH compares with others?
LiNks:
Have you ever dyno'ed your car? If not, what HP do you think you've got to the wheels. I am getting ready to do the same setup as you, plus 5 b FPR and upgraded w/g's. Your trap speed looks great. Can't wait to get mine all together and make some passes!
pilot996tt - I have not yet dynoed the car, I am hoping for around 500 whp and with that trap i think it should be around there more or less, and I do have the wastegates and 5bar as well, i was told they are a must with the setup.
Seal Grey Matte - I am going back Wednesday night, I think Tim and Eddie from RPM are going to try to come and some other guys i know, you should definitely try and get out there. I have to get my 60ft down and lay a good time down! No safety equipment needed besides a helmet and that is for 11.5 and slower, not sure what the next stage of safety equipment is after that, it might be fire suit and 4 point cage.
125 is a good trap. I think 125 and above is a good level to be at...
For 11.499 or lower my local track (IRHA rules) requires:
SFI rated harness within 2 years (I got a 6 point Simpson)
Fire Jacket (I chose a one-piece suit instead)
Roll Bar (not cage - Techequipment passed inspection)
Fire extinguisher within drivers reach (drivers side mount)
Helmet
and I thew in an R3 head and neck restraint for good measure...
After running an 11.515 with my old K16/24 set-up (now Elliots) one of the track officials stopped me and said "any faster and you will require a fire suit and roll bar". That became my goal, but couldn't do it that day, so I went back the following season with K24/18G's and ran an 11.1 on the first pass...
I went prepared with all the goods listed above, so my day was not over.
Helmet
Hi. LiNks car is one of our K24 kits! his car is all wheel drive with stock rubber. The car was ran at E-town ( Eddie and I were there racing for green). LiNks....you need to get that 60ft down... Tim
