.9 bar of boost maximum
Old 07-25-2004 | 12:42 PM
xico's Avatar
Exotic Performance
xico is infamous around these parts
my car is only boosting .9 bar max. Any ideas of what i should look for in the way of a boost leak to correct this condition, before it was boosting 1.3 bar
Old 07-25-2004 | 01:36 PM
BlackBear's Avatar
BlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud of
Could be in a moderate limp mode because of a problem.
MJC123's Avatar
Senior Member
MJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud of
or a bad diverter valve or loose hose
Old 07-26-2004 | 12:00 AM
PorschePhd's Avatar
You have split a hose. I bet the divertor valve hose. Limp mode will close the TB at .4 or so. You have a leak.
Old 07-26-2004 | 12:19 AM
BCS996TT's Avatar
BCS996TT is infamous around these parts
Did you adjust your wastegates too much with your new setup? If you adjust them too much, you will exceed the 1.3 bar max and the TB will shut down...thus only allowing you to boost max of .9 bar. Even if you dont have a CEL light, etc., there will be a error code that needs to be cleared.
Old 07-26-2004 | 09:36 AM
xico's Avatar
Exotic Performance
thank you all for your help
we found the problem today, it was a split diverter valve hose. my mechanic replaced it and the car is pulling really strong now, 1.2 to 1.3 bar to be exact . It feels like the gravitron ride at the carnival.
Old 07-26-2004 | 10:25 AM
Zippy's Avatar
I'm only seeing 1.1 bar and should be seeing 1.2 to 1.3 bar. I think I have the same problem as you XICO. I can hear a 'whistleing' noise on even the most slight accelerations. I hope it's a leek and nothing more. Glad to hear you found your problem.
Mike
Old 07-26-2004 | 12:27 PM
PorschePhd's Avatar
Ha Called that one!!
Bill,
Their program will not close the TB at 1.3 bar. The feature was removed on this setup.
Old 07-26-2004 | 12:53 PM
cjv's Avatar
cjv
Moderator
Re: thank you all for your help
xico,
S Car Go Racing makes a diverter valve hose that won't split. If you replaced the split one with a stock one it is just a matter of time before it splits again. It costs about $150.00.
Rguy
04-13-2020 12:11 AM
ModBargains
McLaren Vendor Classifieds
10-13-2015 04:41 PM
ModBargains
10-13-2015 04:40 PM
proTUNING Freaks
09-15-2015 08:28 AM
Suds26
09-02-2015 02:33 PM
Quick Reply: .9 bar of boost maximum
