Clutch issues?
Clutch issues?
Today I started up the TT and was going to take it for a spin. Clutch was very stiff to push in. Upon pumping the clutch it felt like it was grinding against something. But, when you put in gear and release, itll pop right out like normal. Only when you push the clutch down does it feel like wierd. Clutch going out? Clutch Fluid? Ball Bearing?
If the clutch is stiff when the engine stopped, but feels normal once the engine is started, that is most likely your clutch accumulator.
If it's always stiff (haha) that is something else, which I am unfamiliar with.
How many hours labor is this? Is there anything I should also do if this is going to get done? I guess I am bringing the car down to Kahler's first thing Monday Morning. There goes the Stimulus check.. HAHA
The part is about $100 and it's been stated here before that quotes are around 3 hours labor. You can do this one yourself, as someone here wrote up a nice DIY on it.
I'm waiting on my lift to be serviced so I can do the slave cylinder at the same time...Typically if one goes, the other isn't to far behind.
Mike
Mike
Any reference nos of the parts needed for the fix, looks right on my symptoms is it un safe to run a 12 lap race with this happening???
You can damage your tranny if you're trying to shift and the hydraulics don't allow it, and you then "FORCE" it.
Contact Steve at Suncoast... Parts for Slave and accumulator are about $300-400 total shipped...
Mike
Mike
LiquidElephant
08-27-2015 07:17 PM
ECS Tuning - VW
08-27-2015 03:44 PM
2009, 996, 99611623752, 996tt, 99731416600, accumulator, cayenne, clutch, hard, issues, porsche, push, speed, tundra, turbo
