Had my car dyno'ed today!!
#31
Already logged. Well within duty cycle parameters.
#32
Looks like someone's obviously in good hands. Data logging gives me warm and fuzzies.
What was the peak duty cycle %?
#33
Good points Seal.
#34
Tom -
You can get VP Streetblaze 103 in the 5 Gallon pails that are sealed. It's easy to store and transport for those track days. I keep 2-3 in the garage at all times and every few fill ups throw 1-2 in to help bump things up when I want to turn the boost up (which lately has been all the time)
You're power looks spot on, again Dynos are great to make comparisons on, however it's difficult to compare 2 cars on 2 different dynos at 2 different times / temperatures. If you're bench marking against a previous run on the same dyno it is a much more accurate tool.
#35
Peak duty cycles is about 92% of constant driving. The AFRs (while still lagging from the HP curves on the graph), still show that the fuel in not tailing up at the high end where you start to see fuel starvation on these cars. 60 lb injectors would give a little more head room (probably drop duty cyles to 80ish%), but I think Tom is more apt to turn it down a little until he gets his arms around it. So it's all good....
#36
What the heck is a land and sea dyno?
I'd turn it down for good measure. Anywhere near 700 hp is not good on stock internals for the type of duration and heat that you drive in. And it'll probably make you a worse driver before a better one.
#37
Protomotive program will give you a nice 500hp curve under 1.0 bar of boost. This power is perfectly safe to run most tracks. Anything above 500hp, you will have to deal with AFR, heat soaks, wears and tears etc.,etc..
#39
Tom -
wish the track had it!!
#42
15-17% loss through the G50 tranny is standard. If running AWD, then 22-25% is normal. Tom is just RWD these days. Also this was the second run and down from the first run at 575. Just the dyno operator did not save it. But still, this ain't a bad pic. We could have done it on a Dynojet and gotten an extra 75HP
Also on the dyno (the dyno is a Land and Sea), the AFRs lag a little from the HP / Torque curves on the graphic output. If you notice, the AFRs do not change when I hit the gas at 3000 rpms. They do not change until 4000. So the lag to reality is just over 1000 RPMS. So at peak torque, the AFRs are more like 12 not 14. We are adding a little more fuel though to make the AFRs are little richer and try to get down to the 12s a little faster.
Chris Green
#43
bob, there is no way it would make 75 more hp on a dynojet I own a dynojet 424x and i live on my dyno with my 996 in RWD of course it make's the same HP that tom's car makes with 24/18g's stock fueling @1 bar. Did you log TB percent? it looks as if it starts to close up around 6000rpm's cause power drops off very hard. mine peaks around 6100 but stays up around 540 untill 6700.
Chris Green
Chris Green
The loss after peak is a hardware issue that is being addessed.
#44
http://www.land-and-sea.com/
They actually make a great product. When my wife and I were looking at opening a tuning shop back in 2001 we met with these folks and they were on our shortlist of dyno machines to buy, primarely due to their software and customer support. It's a great machine overall and very well made... Not sure what's gone on with the company in the last 6 years since we scrapped the "custom shop" idea and went with our consulting firm, but it sounds like they're still in business...
Good numbers Tom, but I'd dial it back. I've considered doing that myself!
1.0 bar boost on a road course with our cars is nuts!
Mike
Mike
