A little bummed out.
Old 07-30-2004 | 11:21 PM
Sloth's Avatar
Sloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud of
I thought that Porsche wheels were designed to be hubcentric. Does it mean that if the wheels are not hubcentric that the car is being supported by the wheels studs alone. Surely that can not be a good thing from a performance/strength standpoint.
Old 07-30-2004 | 11:29 PM
Y65MPH's Avatar
Y65MPH is infamous around these partsY65MPH is infamous around these parts
I am guessing the wheels are after market. But basiaclly the wheels are moving around on the studs. Not a good situation at all. If they are Porsche wheels then the problem is something else.
Old 07-30-2004 | 11:31 PM
Don Relentless's Avatar
Don Relentless is infamous around these parts
definitely NOT hubcentric if your wheel guy says he thinks you should use a 1 mm shim. obviously you have a gap in the hub. that is a BIG issue, i would return the wheels, forget a shim. highly doubt it's the suspension.
Old 07-30-2004 | 11:35 PM
Sloth's Avatar
Some further info on hub centric v lug centric...
http://www.miata.net/garage/hubcentric.html
http://www.240sx.org/faq/articles/hub_centric.htm
at bottom of page...
http://www.customwheelsmarket.com/higperwheel1.html
A place that sells hub centering rings, there should be a few out there...
(no affiliation)
http://www.justforwheels.com/index.jsp?cat=hubcentric
Old 07-30-2004 | 11:39 PM
Sloth's Avatar
Re: feedback
Originally posted by xico
Britt, i have the same wheels and tires and mine do not shake at all at any speed; it has to be a balancing issue.
Xico,
Did you have to use hub centering rings to get your wheels to fit right??
Old 07-31-2004 | 12:22 AM
Wheel Experts's Avatar
hey guys,
custom wheels shouldn't need any type of centering "help". if there is a shim, i'd have the wheel(s) remade
http://www.wheelexperts.com
email: peter@wheelexperts.com
HRE | Forgeline | Modulare | PUR | TechArt | Brabus | Novitec | Vossen | Avant Garde | Vorsteiner | BBS | Eisenmann | Quicksilver | Brembo | KW | WALD | +many more
***DFW Showroom now OPEN at 4515 McEwen Rd in Dallas, 1 block West of the Dallas Galleria***
***WE SHIP WORLDWIDE!!!!!***
Old 07-31-2004 | 12:58 AM
Zippy's Avatar
Originally posted by greyghost
... The wheel is not 100% snug on the hub... this was illustrated to me by the alignment tech. ...
Dude: This deninately is a problem. Forget the shim and get the stupid wheel replaced! I'm suprised you can even keep it on the road with a loose wheel.
Mike
Old 07-31-2004 | 01:37 AM
HotRodGuy's Avatar
The wheels are balanced, I watched them do this myself. The wheel is not 100% snug on the hub... this was illustrated to me by the alignment tech. He said that they make shims that might help this but I have no clue where to get them.
As far as bump stops go, what symptoms are produced when these come into play.
Yep, it's most likely you need some hubcentric rings. I just put some on my wheels and all my problems went away. They are cheap to. Discount Tire sells them on ebay (metal ones, not the cheap plastic) and they will find the ones you need when you give them your wheel and tire info.
The problem is w/ aftermarket wheels is they make them in one size and make them for the biggest hub the wheels will fit on. So let's say VW has a big hub, they'll make it to fit VW's and then supply rings for say a toyota.
But if the wheels were custom they should fit w/ no issue.
Old 07-31-2004 | 03:44 AM
03-turbo911's Avatar
Senior Member
I have the same wheelshake problem as Greyghost. My wheels are HRE 540R in 19"s. I thought that it might be a wheelbalance problem so I'm taking them to another place to get them balanced correctly. I certainly hope it has nothing to do with the wheels not fitting correctly on the hubs.
Old 07-31-2004 | 04:21 AM
Senior Member
Ruiner, yeah I agree. The place that balanced them probably didn't do a good job.
Old 07-31-2004 | 09:01 AM
D2-Autosport's Avatar
D2-Autosport is infamous around these parts
Is it possible that you bent the inner lip? Perhaps when you have them re-balanced (or whatever you choose to do) you can watch them on the high-speed balance machine.
If the wheel is bent or in anyway deformed it will yield vibration.
Good luck with your dilema (s)
randalldahme
02-19-2016 03:56 PM
MeddlingKid
10-20-2015 07:43 AM
alpha motoring
10-02-2015 12:04 PM
NBoost
Detailing
09-29-2015 10:06 PM
Quick Reply: A little bummed out.
