octane booster
What exactly do you hope to gain? Do you
need it? What have you done to your car?
I'll bet that with most 996tt's and most
circumstances, there will be zero seat-of-the-pants
difference in what your car does, if you did a
real 'double-blind' test, so you didn't know whether
you were running with a booster or not. Heck, I *know*
my car runs smoother and faster just after I've
detailed it. If you're very consistent at the track,
a stop-watch might detect it.
All that being said, the easiest way is to run half/half
unleaded race gas.
Joe
unleaded race gas.
Joe
aren't. And "better" is as I described it, for the most part. If you
taped over your speedo and boost gauge, I'm betting most folks
wouldn't be able to tell if they didn't know what was in the tank.
Heck, running 87-octane can take you perfectly safely across the
country in the stock car.
Joe
Have you considered water/meth injection. We are using it on 91 octane cars with very positive results.
Its a better alternative then constitutional buying/mixing octane booster.
Tony,
No I really haven't. please gimme the lowdown on it. I live at 3,200 feet above sea level and have a 2002 996tt tip, stage 1 fvd.
How much $?
How reliable?
Fuel economy?
Safety?
Emissions?
Performance characteristics?
Ease of installation?
How much $?
How reliable?
Fuel economy?
Safety?
Emissions?
Tony,
How much $?
-$350 to 1000 depending on the system you install.
How reliable?
-VERY
Fuel economy?
-Basically unaffected
Safety?
-Very safe. If installed properly adds no danger to the car or driver.
Emissions?
-Unaffected
- =)... Its more or less like having 100 octane in your gas tank at all times. We like to install this on cars that aren't guaranteed access to 93 octane at all times.
- Installs usually take 4-6 hours and most DYI'ers can complete themselves.
How much $?
How reliable?
-VERY
Fuel economy?
Safety?
Emissions?
-Unaffected
Thanks,
Tony
Try xylene or toluene available from paint stores.... ;-)
http://www.gnttype.org/techarea/misc/octanebooster.html
Xylene
R+M/2...117
Cost...$2.75/gal
Mixtures with 92 Octane Premium
10%...94.5 Octane
20%...97.0 Octane
30%...99.5 Octane
Notes: Similar to Toulene. 12-16 ounces will only raise octane 2-3 *points*, I.e. from 92 to 92.3. Usually mixed with Toulene and advertised as *race formula*.
FORMULA 3
Methyl-tertiary-butyl-ether (MTBE)
R+M/2...118
Cost...$3.50/gal
10%...94.6 Octane
20%...97.2 Octane
30%...99.8 Octane
Notes: Oxygenate. Very common in octane booster products. Has lower BTU content than toulene or xylene, but oxygenate effect makes the gasoline burn better and produce more energy.
FORMULA 4
Methanol or Ethanol
R+M/2...101
Cost...$0.60 - $1.75/gal
10%...94.3 Octane (Methanol)
10%...94.7 Octane (Ethanol)
20%...Not Recommended
Notes: Methanol is wood alcohol. Ethanol is grain alcohol and found in Gasohol in 10% ratios. Both alcohols are mildly corrosive and will eat gas tank linings, rubber and aluminum if used in excessive ratios. Main ingredient in "Gas Dryers", combines with water.
FORMULA 5
Isopropyl Alcohol and Tertiary Butyl Alcohol
R+M/2...101
Cost...$0.60-$1.50/gal
10%...94.5 Octane
30%...Not Recommended
Notes: Similar to Methanol/Ethanol. Isopropyl Alcohol is simply rubbing alcohol.
FORMULA 1
Toulene
R+M/2...114
Cost...$2.50/gal
10%...94.2 Octane
20%...96.4 Octane
30%...98.6 Octane
Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 *points*, I.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores.
FORMULA 2Toulene
R+M/2...114
Cost...$2.50/gal
10%...94.2 Octane
20%...96.4 Octane
30%...98.6 Octane
Xylene
R+M/2...117
Cost...$2.75/gal
10%...94.5 Octane
20%...97.0 Octane
30%...99.5 Octane
FORMULA 3
R+M/2...118
Cost...$3.50/gal
10%...94.6 Octane
20%...97.2 Octane
30%...99.8 Octane
FORMULA 4
Methanol or Ethanol
R+M/2...101
FORMULA 5
R+M/2...101
10%...94.5 Octane
I throw a 20L can in my old suburban's 155L (94 gasohol - say 92 real gas) tank and can run 12 PSI boost with the water/meth injection turned off.
I've tried the ~ 1L TORCO Accelerator with 3/4 tank of 91 octane in my car a couple of times. Ran the 100 octane file perfectly.
10-02-2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
10-01-2015 11:48 AM
shifterkartracr
SoCal
09-24-2015 11:05 PM
