New Low Pricing on Softronic ECU Flash K16 and K24
Vivid Racing has worked with Softronic the leader in Porsche ECU flashing and data checking for Porsche Motorsports to offer a new special price to 996TT customers.
The new special price is for K16 and K24 map files. - $1549.99 including the $150 ECU Flash Cable. Upgrade to the Durametric Cable for just $250. The Durametric cable allows you to turn off Airbag lights, CELs, Datalog, Check AFR mixtures from the factor wide band O2 sensors, and more. Read more on www.durametric.com.
Tired of the power your K16 or K24 car makes, it is just a $300 revision to get the new map for your K24/18G, K16/16G, GT2860, GT3076 turbo mapping once you purchase the parts from us.
If you are interested in flashing your car and having it done by someone with more then 20 years in Porsche performance then Softronic is your choice!
Softronic is the only company that uses Porsche factory tuning equipment and tools for the finest software available. Softronic has more than 30 years in fuel injection experience and are the lead company in data checking of Porsche Race Cars.
By reflashing your Porsche 996TT with the standard K16 turbos, you will expect to gain 80whp and 90ft/lbs of torque with corresponding modifications (diverter valves and K&N flat panel filter). With the K24 turbos, you will see about a 40HP gain and 60ft/lbs of torque. Vivid Racing has proved the performance of the Softronic compared to its competitors. We have included a dyno sheet below.
What are the benefits/functions of going with Softronic compared to the competition?
- Softronic does not require the removal of your ECU from the car. There is no down time at all.
- Softronic reflashing is done via a Client Cable included in the price that is connected to the OBDII port. The customer simply plugs the cable into the car and reads the file with a laptop per the instructions with the cable. Once the file is downloaded, it is emailed to the Softronic secure server where the file is manipulated and then emailed back to the client. The client simply uploads the file and they are done. Total process is about 1 hour during normal business hours. Other accomondations can be made.
- If the client is not comfortable with the simple process, he/she can send the ECU to us to have it bench flashed. The client cable will not be shipped. ECU removal instructions are HERE.
- Reflashing is done according to additional modifications (Intake, Headers, Exhaust) to enhance power gains.
- ECU Reflash alters boost, fuel, and timing maps for increased horsepower and torque.
- Customer can upgrade to the Data Logging Client Cable which allows them to get real time data analysis with the Softronic Diagnostic Tool.
- View the Instructions on OBDII Reflashing with Softronic Here.
***For questions or special tuning needs, contact our tuning department.***
We are still running this promotion guys. If you have flashed your car in the past and want to upgrade to a new turbo file, just contact us. If you are interested in getting your car flashed, give me a ring and I can help guide you through your questions.
BlackMarketRacing
12-03-2015 10:46 AM
09-01-2015 03:16 PM
08-20-2015 12:17 PM
