New videos of today's Run in Mexico
Old 07-29-2008 | 08:15 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
Originally Posted by DLSJ5
Robert your car is definently capable of sub 9's. I hit 8.67 on approx 8.5-9psi of boost, when you and I ran I was running 10psi, about 30WHP more. I ran the 8.6 in 50 degree temps. I think that last shift is really hurting you.
There is one location that is flat and we should be able to get a good time. The only problem is that we go under a large underpass and the satellite always drops for a second. Will that affect the run?
  #77
Old 07-29-2008 | 09:01 PM
Turbo Fanatic's Avatar
RS38: do you think my dyno graph is due to an optimistic dyno?
I ran it at 1.1 BAR on 91 octane.
If the turbos are good for 570Hp, 516 Rear Wheel HP would equate to about 10% drivetrain loss.
Originally Posted by RS38
ok 1.2 bar:
If I look at the K16 compressor map I can see maximum air mass flow of ~0.17 to 0.18 cubic meters per second per bank. That equals to 480/500 engine(!) or flywheel HP.
this power in an heavy 4wd convertible makes the other cars look very stupid if they seem to be nearly equally fast...
edit:
ups sorry, you mentioned a TTS: the k24 can blow a bit more up to 0.20-21 cm/s which can be up to 570 HP at a very bad compressor efficiency level (-> hot air intake), but opcoming detonation could be fixed by your very high rated fuel.
didn't you try any 60-130 with 1.2 bar and 109 octane?
  #78
Old 07-29-2008 | 11:10 PM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
Originally Posted by robertp
A few more
HOLY **** WHO INVITED BEN STILLER!?!!!
  #79
Old 07-29-2008 | 11:36 PM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
Ben "The Predator" Stiller. That has a nice ring to it.
  #80
Old 07-30-2008 | 03:59 AM
robertp's Avatar
15% loss for AWD????
  #81
Old 07-30-2008 | 06:22 AM
RS38's Avatar
RS38 has a spectacular aura aboutRS38 has a spectacular aura about
1.1@91 should be a more health one, but would not reach 570HP.
where did you post your dyno plot? what I heard is that especially the dynojets are VERY optimistic which is due to it's low costs and that it has no real brake to hold then engines longer on certains revs. An engine that revs to redline can output more power than if it lasts longer (increasing temps).
  #82
Old 07-30-2008 | 06:29 AM
RS38's Avatar
btw: most/all tuners in germany do not provide more than true 540-550 engine HP with 93-95 octane (US-spec) with stock K24 due to reliability issues. increasing boost will put the intake air above 65 degrees celsius, which makes the ECU becoming operating safely.
It is not very common here to get race fuel when you are on the track.
BTW2: I never saw an EBC here in a 911 Biturbo, and replacing Wastegate and DV/BOVs is also quite uncommon, but I think it is very likely to be considered.
  #83
Old 07-31-2008 | 04:56 PM
robertp's Avatar
ok 1.2 bar:
edit:
So you think I am getting 570HP (crank) without an exhaust, Plenum, or headers?
  #84
Old 07-31-2008 | 10:38 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
I can not open any of the files Robert to view the videos, any advice.
  #85
Old 08-01-2008 | 01:10 AM
DLSJ5's Avatar
DLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond repute
It could affect the run, yes.
  #86
Old 08-01-2008 | 05:42 AM
RS38's Avatar
no, unlikely, the K24 should be capable of, if all other bolltle necks are removed.
  #87
Old 08-01-2008 | 09:22 AM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
Hey guys, there is a chance i can't make it out this week.
Becareful out there guys! See you next week, if i can't make it
  #88
Old 08-01-2008 | 10:37 AM
Zuluracerx's Avatar
Zuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant futureZuluracerx has a brilliant future
Let's be sure to hook up the next Saturday and see what's what!
  #89
Old 08-01-2008 | 02:03 PM
robertp's Avatar
You have to right click on them and save them to your desktop. They are too big to view from the server.
  #90
Old 08-01-2008 | 02:06 PM
robertp's Avatar
I saw the video of your car. We are in trouble.
Quick Reply: New videos of today's Run in Mexico
