High octane fuel
High octane fuel
What are you guys running in your cars? I would like to hear from the Protomotive guys in particular. I'm leaning towards the VP MS109E or the MS103.
See the link: http://www.vpracingfuels.com/vp_01_fuels.html#unleaded
All comments and recomendations are welcome!
It depends on the state. In CT I can only get 109e.
I recommend 103 if you have a pump gas tune and no way to increase boost and 109 is you have an ebc or if you are running one of our true race gas files.
really depends on YOUR tuning and amount of boost you run.
I ALWAYS run 100 octane at the track. not for hp as much as to prevent running lean and also keeps cylinder temps down (from what I am told)
on the street I run 93 but really never have any sustained boost will street driving.
my AFR's are right on the money with the Protomotive programing, and this is the key.
VP109 is NOT 109 octane -- the name of the fuel is deceptive. In contrast to other VP fuel names which accurately reflect the R+M/2 octane rating, VP109 is actually 105 octane (R+M/2).
Before I switched to leaded fuels -- C16, then C12 -- I used to run Sunoco GT Plus, which is 104 octane (R+M/2). This Sunoco fuel is only 1 octane point less than VP109, but considerably less expensive.
Craig
Craig
Craig
I just tried VP100 for the first time (1/3 tank) and I could already tell the differences (comparing with 91 in CA). For those that are considering, give it a try... you'll like it.
Craig
Craig
