Scratch through clearcoat - what would you do?
I have a couple of scratches on the right of my car behind the rear passenger window on the drivers side that have gone through the clearcoat. They can't be buffed out in any way and the body/paint shops I went to (evidently the best in town) were not comfortable blending just the scratches since they are in an akward spot.
As a result the suggestion was to paint about half the driver side of the car specifically the rear quarter panel and roofline above the windows. Fine ... but my concern is if I sell my car, would this potentially raise concerns with a buyer? The car has never been in an accident of any sort. I think the scratches were a result of someone who "casually" keyed it while walking by.
What would you do? - repaint or leave as is. All the shops I went to said leaving as is would not do any further damage i.e. no concerns with rust, but the bigger issue are that the scratches bug me although most people might not notice them unless looking very closely. The car is Artic Silver by the way.
I've had to do this on several cars- a fact of driving (and parking... )
If it bugs you enough, then have it done. Just document the damage. Pictures, etc. Take the work order showing what was done, put them in the maintenance folder with all the other documents. New owner can review.
Pricey repair, eh? Rope front and rear windows, remove a bunch of stuff, remove quarter window. $800-1000?
GL
A
GL
A
Ard - you are spot on! You must be friends with the repair shops in my area. I was quoted anywhere from $800 to $1200.
This is the only issue that is preventing my car from being a "perfect" example, but then I won't have the luxury of saying no paintwork if I sell the car in the future.
But, it does bother me enough that I'm leaning towards the repaint.
GL
A
GL
A
So a deer made the decision for me. Ran out an nailed me (yeah, I was semi-sideways trying to avoid it) right on the rear fender.
All shops all over the country basically use the same estimating software. All that varies will be hours here or there for color sanding/blending...and of course the hourly rate.
GL
A
PS No rear wiper any more... bumperplugs
You can't fill the scratches with clear, sand w/2500 and re-buff?
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
But the difference between clearcoating a panel, and coloring just the scratched area and THE clearcoating the panel is only about $200. You still need to mask, isolate and clearcoat the entire fender.
Any shop that proposes a 'spot clear' ...don't. You need to have the clear coat in one continuous sheet all the way under any trim/panels/rubber/etc
Clay bar first. If that does not work, it will at least make it less visible.
Use Zaino Clay Bar.
http://www.zainostore.com/
Use Zaino Clay Bar.
Use Zaino Clay Bar.
Use Zaino Clay Bar.
(Suspiciously, the Zaino Clay Bar was IDENTICAL to the Mothers Gold bar- down to the cellophane wrapper... then they changed the color.)
