Buy AP droplinks at your own risk
I should have listened to others. After having my front end sound like it's falling off because AP droplinks won't stay tight, removing my front wheels 10+ times over the last couple of months to tighten them . . . you guessed it, my right front droplink broke. What a waste of 200+ bucks. Having to jack the car up and removing and installing the wheels was more of a pain then losing the money.
Dan at Vivid (after this thread, I guess I won't be receiving any refund from AP/Vivid) was nice enough to send these overnight to be matched up to GT3 sways. They immediately started loosening up and had to be retightened weekly if not earlier. After loosening up so many times I was not sure if they were properly adjusted for 0 preload so today I was taking my wheels off to set them up with 0 preload and loctite the length adjusting nut as well as install an extra nut to lock them together.
That's when I found the broken droplink. Now I know why they were so quiet. The clunking I always got was on the right side, even tho both sides loosened up.
So buy at your own risk. Time to go buy real droplinks.
Ken, not going to comment on the links, I have never had these before, I'm sure Dan will come on and give some feedback. I have to admit it is one product that I have had a lot of bad experiences with. I have purchased a few sets of drop links from reputable companies and had a them all snap on me it is nothing new. What I will say and I have said this a million times now, the TRG Drop links for the front and the Tarrets for the rear have never once gave me any issues, now 2 to 3 years of hammering the car around tracks all over Europe.
I've got the same setup as Stevo and I've noticed them loosen up a time or two on one end lock nut or the other. I put a small tab of blue Loctite on and they stopped loosening up...
Mike
Mike
Agreed, if you align the drop link so that the spherical bearing is centered, this will give the bearing good even movement throughout, it's fine tightening these up but if not evenly aligned and the drop link is not best quality this is when these will snap. What I tend to do is tighten (not over tighten) so that there can be a little movement, so the everything can kind of bed in and adjust itself then I check and re-tighten.
looks like the top of the rod end broke. been out of town for 6 days and have not seen an email or anything about his.
All you have to do is contact me and I will send you out a replacement. You can see it is the rod end that snapped off not the center CNC machine part that we make. The problem is that when guys run these GT3 bars, you are trying to stretch it to the furthest whole possible I bet. It also looks to me based on your pictures that you have 996C2 links, not links for a turbo, do you have a turbo? Call me and your problem will be solved.
adnanm3
11-22-2023 02:43 AM
