PSS10s and GT2 sway bar don't mix?
Another thought, do pss9s and pss10s have the same hardware, are they interchangeable?
If the rd ht is not excessively low it must be the pss10s, any comparable shots with pss9s.
GL either way.
GL either way.
A question for Dan's question - how would I know? I can't see my suspension while I'm driving. As with Surgeon, it doesn't make any obvious noises, but if the two things are binding against each other, I wouldn't expect any noise. I'm still hoping to see someone post some stock pics. Anyone out there?
Different cars I know, but mine is lowered with gmg sways, they have a bend in them that seems to be designed around just such a problem. I'll post up a pic if it helps later.
That looks like a perfect solution, and I may have to take you up on it, but let's give it a couple of days and see if someone posts an answer here. Like you said, you've sold lots of PSS10s and sway bar combos, there must a way to make them work together.
04-28-2022 12:38 AM
