evoms GT 660 stats
Old 09-03-2008 | 09:54 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
I have no doubt the car can do high 10's on a strip.[/quote]
Please put down the crack pipe.[/quote]
I haven't done that a quite awhile; I drive my car to get high now days. Besides, it is hard to take advice from a "tweetyphobic".
Old 09-03-2008 | 09:55 AM
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
^Was he talking about a 60-130 time "on the strip?"
Old 09-03-2008 | 10:01 AM
sharkster's Avatar
Please put down the crack pipe.[/QUOTE]
The car is certainly quicker than my Tip was when I ran a 10.9 in 2004 so I don't believe there is any crack on offer...
Old 09-03-2008 | 12:13 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
I guess with that weight youd need a little more HP to run those times, that makes sense. I am thankful I dont have a cab when it comes down to times.
Old 09-03-2008 | 12:18 PM
torresmd's Avatar
torresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond repute
When I drive my car I sometimes feel like I have been smoking crack.
Old 09-03-2008 | 12:20 PM
MY996TT's Avatar
Very true LiNks, Cab is like another 250 lbs on top (doesn't even include the Tip). I do sometimes think that what could she run if she is a coupe. But other times, top down, Calif sun... I guess nothing is perfect.
Old 09-03-2008 | 12:23 PM
sharkster's Avatar
Crack addicts that we are
Old 09-03-2008 | 12:24 PM
MY996TT's Avatar
And keep going back for more.
Old 09-03-2008 | 12:31 PM
torresmd's Avatar
If I could only loose weight while driving my car!
Old 09-03-2008 | 02:36 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
I ran a 9.1 60MPH to 130MPH. I also saw a 8.9 and 9.0 but the file ended up corrupted and can not be officially verified. I also have cab. My mods are flash, DV and clutch only. I would expect better times from a package kit????
The problem with the cabs is that they can not reach 130MPH in 4th gear (6 speed) unless you raise the RPM limiter above 7000.
Old 09-03-2008 | 02:53 PM
MY996TT's Avatar
robertp,
Did you mean "the problem with the cabs" or " the problem with the Tip"?
Old 09-03-2008 | 03:09 PM
robertp's Avatar
6 speed cabs. Mine has to be in 5th gear to hit 130MPH.
Old 09-03-2008 | 03:25 PM
torresmd's Avatar
Your cab is a freak. I have seen the vids. Not to mention you are a good driver.
Old 09-03-2008 | 05:16 PM
FASTLANE's Avatar
FASTLANE has a reputation beyond reputeFASTLANE has a reputation beyond reputeFASTLANE has a reputation beyond reputeFASTLANE has a reputation beyond reputeFASTLANE has a reputation beyond reputeFASTLANE has a reputation beyond reputeFASTLANE has a reputation beyond reputeFASTLANE has a reputation beyond reputeFASTLANE has a reputation beyond reputeFASTLANE has a reputation beyond reputeFASTLANE has a reputation beyond repute
hey Robert, thanks for giving me something to do tomorrow try to hit 130 in 3rd
Old 09-03-2008 | 05:40 PM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
Originally Posted by MY996TT
Maybe I exaggerated a little, maybe low 11's. The GT660 is running on GT2871 and has quite of bit of low-end power. It is perfect for stop and go type driving and I'm not a high speed driver. Running 1/4 doesn't require much "high-end" power.
Running the 1/4 is all about top-end power. The only time you're in the low-end is off the line. The rest of the time you are at/near redline.
Quick Reply: evoms GT 660 stats
