OT - Valentine1 & Laser
Oak - That's exactly where my transponders are mounted also.
Racer63 - Yes, I also had the rear transponder mounted - it mounts at the top of the rear license plate. Although it's clearly visible if you're looking for it, it sort of looks like it belongs there. I would never notice it if I didn't know what it is, and nobody else has ever noticed it.
Do either of you have DIY instructions for how your units were installed?
Oak, do you need the small "concealed display" unit from Valentine to interface with the laser jammer? Which jammer did you use?
Thanks in advance.
Racer 63, Sorry no instructions, just follow the schematics from Lidatek and V1. You have my pics for reference for wire routing. It's pretty easy, once you have your lay out. It's been awhile since i did the install.
The V1 remote/concealed unit isn't necessary, I just installed the Lidatek LED on the top of the V1 remote/concealed unit to incorporate all the LEDS in one location. Visually much easier.
TexZ
12-01-2015 01:29 PM
panas001
09-27-2015 02:51 PM
