Need source for slotted rotors
I upgraded my brakes to Big Yellows with 6 piston front calipers and 350mm discs at all corners. My new discs are already starting to make small cracks at the drilled holes, so I need to find some slotted rotors to replace the fronts. Backs are OK as is. Anyone know the best place to buy them?
Frozen rotors started to make their slotted rotors.
http://www.frozenrotors.com/search/i...lectedIndex=15
http://www.frozenrotors.com/store/2373%20FZR%20SL
360 each for the fronts. I don't think they make the slotted versions for the rear though.
are slotted better then cross drilled factory type rotors? I thought the cross drilled were the best
Larry,
Check this link out. good Luck!
Michael
https://www.6speedonline.com/forums/...ml#post2050854
Michael
https://www.6speedonline.com/forums/...h-fiction.html
For less than $1000 you can have 350mm rotors in two piece slotted, floating or rigid mount and Coleman will make them in any type of ventilation you want...Once you get the hats made, your replacement rotor/hardware will run about $400 for everthing, both fronts...Michael, What was your total cost for your setup? I'm posting your link in the thread listed above so others will have it...
Mine have lasted me for 15 trackdays and were used by a member on rennlist for a couple track days as well.
I haven't found anything more cost effective, especially for longevity and tracking!
Mike
Mike
Two Piece 350mm Steel Rotors to Replace PCCB
Mike,
Cam at Maltby Motorsports had my Gen 1 ceramic rotors blueprinted at a CAD shop, then had the steel cup rotors machined from the CAD info. From there, he mounted the hats from the old ceramic rotors, to the new slotted steel cup rotors, using the same, but modified hardware. I have 8K miles on the rotors and Pagid yellow pads. This is my second season with them. I guestimate that I have 4K miles track miles on the new set and feel no ridge at the outer portion of the rotors and see minimal wear. I believe I paid approx. $1,500 for both (before Wash. State tax) and now that he has the blueprint, I imagine he would charge less. This guy is a MacGyver and seems to be able to make any part the Porsche Club guys need. I am preparing to a write-up explaining my process and have photos to go with it, so if you want to see the photos ahead of that, let me know.
Michael
Michael
Photos of Replacement 350mm Steel Rotors for 996 Turbo
Mike,
I'm at the office and will send the photos to you this evening from my home. I am hoping to get things together, along with costs, before the end of the week to share with the others.
Michael
Michael
