Took the Rejex Challange - Ohhh My
Old 08-23-2004, 03:25 PM
SANDOVAL's Avatar
Banned by Moderators
SANDOVAL has a spectacular aura aboutSANDOVAL has a spectacular aura aboutSANDOVAL has a spectacular aura about
Is the climate moist?
  #47
Old 08-23-2004, 11:15 PM
HotRodGuy's Avatar
Originally posted by cjv
Hold on a minute. I am relating to my experiences with sealing waxes. I do not know if this applies to Rejex. I wish someone in the know would expound on this.
I was saying you were right. you shouldn't be putting rejex over a real wax. It should go on a properly prepped surface that's polished/clayed/cleaned etc. If you want to add a wax it should go ON TOP of rejex. Not underneath. That is "if" you want to apply a traditional wax.
  #48
Old 08-23-2004, 11:16 PM
HotRodGuy's Avatar
Originally posted by john stephanus
Has anyone experienced some hazing from using Rejex? I see some streaky hazing on the hood. Any ideas on how to fix it from your guys that are more experienced? I think the surface was completely clean...I carefully washed the car with blue Dawn prior to applying Rejex.
Thanks,
that is most likely from applying to much product or not allowing it to cure enough before wiping off. Is your car black, by any chance?
  #49
Old 08-23-2004, 11:20 PM
john stephanus's Avatar
john stephanus is infamous around these parts
Yes...my car is black. I think it cured for long enough...at least an hour. As for too much product I guess that is possible. Should I just remove it with blue Dawn and re-do the hood?
Thanks,
  #50
Old 08-23-2004, 11:27 PM
HotRodGuy's Avatar
Thanks,
no, the streaking should go away after a wash or two.
these new synthetic waxes out these days are tricky. You use a very very minute amount. It's not like the old days w/ the carnubas and such where you would just pile that stuff on. W/ products like rejex/nxt/zaino a little more then an ounce of the stuff should cover your entire car.
  #51
Old 08-23-2004, 11:32 PM
Thanks much...knew you guys would be able to help.
  #52
Old 08-24-2004, 12:07 AM
Greyghost's Avatar
Greyghost is infamous around these parts
I have gotten the steaking as well. I live in humid Florida and I only have this problem on the hood. Plus, dark cars can be a ***** but I have found that the streaking will also fade in the sun.
  #53
Old 08-24-2004, 12:15 AM
DJ's Avatar
DJ
DJ is offline
I found that spraying a little final inspection over it with a clean microfiber towel got rid of my slight hood streaking
  #54
Old 08-24-2004, 12:17 AM
What is "final inspection"?
  #55
Old 08-24-2004, 12:25 AM
HotRodGuy's Avatar
Final Inspection specifically is a meguiars product. But what he is referring to is basically any quick detailer. A spray on product you use instead of a wash if the car isn't very dirty.
  #56
Old 08-24-2004, 12:31 AM
Got it...will give a try.
Thanks again,
DJ
07-14-2005 08:06 PM
DJ
07-01-2005 03:47 PM
SilverPorsche
02-25-2005 08:36 AM
SANDOVAL
Cayenne 955/957
12-03-2004 03:52 PM
ColorChange
07-21-2004 07:59 PM
Quick Reply: Took the Rejex Challange - Ohhh My
