315's on a 25ET offset?
Old 10-06-2008, 04:58 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Question 315's on a 25ET offset?
It's time for me to replace my tyres
I currently have stock tyres sizes, and stock suspension
My wheels are TechArt Daytonas, and the rears have a 25mm offset (!!)
When I hit a bump I get some rubbing on the rear arches
It's not too servere, and I think it would be resolved by rolling the arches
My questions is... Once the arches have been rolled, do you think there will be enough space to fit 315's on the rear?
Rolled arches, 25mm offset, 315's ????
Old 10-06-2008, 10:03 PM
ezmoney888's Avatar
ezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond repute
That is the correct wheel and tire fitment. You need to roll the fenders and check your alignment. The et25 is an aggressive fitment.
Old 10-07-2008, 01:56 AM
SamboTT@ByDesign's Avatar
+1. A good roll and some negative camber
Old 10-08-2008, 12:11 PM
ant_8u's Avatar
What alignment should I go for on the front and rear?
What should the toe in/out and cambers be?
Old 10-08-2008, 06:26 PM
Small Shrimp's Avatar
Small Shrimp is a name known to allSmall Shrimp is a name known to allSmall Shrimp is a name known to allSmall Shrimp is a name known to allSmall Shrimp is a name known to allSmall Shrimp is a name known to all
I had that setup on my C4S with the Techart formulas and it was lowered on H&R springs and I never had a rubbing issue. Just and FYI.
315x25x19 et 25
Old 10-08-2008, 07:10 PM
For a med. aggressive alignment I would say
0 tow front
.25 tow in rear
-.7 to -1.0 (or max) front camber (minimal tire wear issues in front)
-1.6 to -2.0 camber rear (not much choice on a low car) or as needed to clear
You will like the handeling and braking stability.
Good luck with the rub, remember you will need the good rolling especially with the ps2 tires. They are better but the Continental and Toyo are a little smaller.
tita1989
08-17-2016 03:13 PM
Boldgt
03-23-2016 11:07 AM
s6spd
10-06-2015 08:20 PM
Sakred
09-30-2015 03:51 PM
SaviniWheels
Wheels/Tires
09-29-2015 07:04 PM
Quick Reply: 315's on a 25ET offset?
