Should I get straight pipes?
#61
Exhaust. It would be a cheap way to test the straight pipes without spending the $$$ for someone to make them for you.
#63
as you probably know, x-pipes have been around for sometime and are quite effective at balancing out both sides on front engined cars. I do not know how effective they are if at all with such short runs of pipe like in our cars. I am more interested in the x-pipe for it's drone reduction, or so I hope. I am trying to prove to myself that the sound waves intersecting each other at 90, should cause some interference and some cancellation, but this is probably a pipe dream (pun intended).
That is why I am interested in knowing if the x-pipes people have tried actually cancel out drone, problem is that some people do not notice drone while others do in the same system.
#64
#65
So what is the final take on the pipes, do they really hurt the low end revs ??? Do the bring more power???? PERFORMANCE??? not about the noise.... for track who cares, are they worth putting on over a good muffler without cats???
#66
Just be fore warned , strait pipes at cold start up is disgusting.I found it helped the turbo spool quicker as others will tell you it hurts the low down TQ.It did help my car at low and high RPM, I wouldn't change them because of all the benefits, weight ,power.The only down fall is how loud things really are....I would do them again...no doubt
#67
I decided that I could not live with the noise and fabbed my Europipe loud to fit.
Car is nice and quite in the neighborhood but delicious at WOT, especially when the external wastegates open up..
#68
if you are running straight pipes without cats you can have your programer turn off the secondary air pump(its used to aid in heating the cats at cold start up) this will eliminate the loud poping on cold start up
tim
#69
I have the fabspeed cats with straight pipes and it is loud, but I like it. My neighbors may disagree, however.
I wonder if the highflow doesn't hurt power in the under 3500 rpm range. I think it does, but cannot proove it.
#71
Upper right side of engine. You can hear it hum at startup for a minute or so until the cats warm up (well, maybe YOU can't, with your loud-a$$ straight pipes ).
#73
Correct. By adding extra O2 and fuel more heat is created. Sounds counter-intuitive but it lowers startup emissions. Remove the airpump and you will have super rich starts, higher emmisions and a CEL. A good tuner can elimintate the CEL, lean out the startup condition and possibly trick the OBDII scanner at inspection sticker time, but don't quote me on that. It will not pass a tailpipe sniffer on cold startup. I can't see any advantage in removing the airpump if you are doing it to reduce noisy startups for your straight pipes...kind of like using low calorie whipped cream on a chocolate sundae, it will make little difference!
#75
Thanks Rob. I had that kidney stone for 5 days. That is like labor pain or worse for those that do not know. I had surgery last Monday and will have the stent removed tomorrow. It sucked more than words can describe!
