Front Differential Chewed due to incorrect wheel/tire se up
Rating: Thread Rating: 9 votes, 5.00 average.
  #181
Old 04-24-2012, 06:38 PM
pwdrhound's Avatar
Originally Posted by randomquickness
bringing this old thread back...On my way to Vegas last week my front diff blew out. Had it towed to the dealer in Albuquerque. The car had about 33k miles on 235/35/19 and 305/30/19. This thread is all I found while searching for this issue. The dealership said it's extremely rare for these front diffs to fail.
What exactly failed? The diff or the viscous coupling?
  #182
Old 04-24-2012, 07:04 PM
randomquickness's Avatar
randomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to behold
the mechanic said the whole diff had to be replaced. The gear oil all came out and the axles were flopping around inside. He said if I kept driving it the front would have locked up and caused damage in the rear via the drive shaft.
  #183
Old 04-24-2012, 08:05 PM
Twinturbofan's Avatar
Twinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud of
My experience is you will have trouble (psm, abs, front diff etc) with a 996 tt with 19" wheels with any tire combination other than 235-35-19, 315-25-19. Having said that, my problem is I need tires and I can not find any 315-25-19s anywhere. No Michelins, Nittos, Yokohamas or anything else. Has anyone else been able to locate any? If so, please share.
  #184
Old 04-24-2012, 08:26 PM
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
Sorry to hear about your differential. I have an extra if you need a good deal on one. I am in CO, but freight shouldn't be too bad, especially with a deal :-)
  #185
Old 04-24-2012, 09:45 PM
ard's Avatar
ard
ard is offline
See if all the members that pu pu the concerns about mismatch as "not a problem" followed by "mine had no issues" will chip in and pay your bill.
  #186
Old 04-24-2012, 11:55 PM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
Now that's funny!!! 235-35-19's and 315-25-19's here!
  #187
Old 04-26-2012, 05:10 PM
^ideally that's what I'd like to do, now Michelin needs to hurry up and make the PSS in that size so I won't need to run mismatched tires! I won half off a set of custom built wheels at MFEST while in Vegas though, so I'm going to be running 19x8.5 and 19x12 with a nice concave profile.
  #188
Old 04-26-2012, 06:26 PM
ard's Avatar
ard
ard is offline
Nice score at mfest.
I run 9" rims up front- allows for 265/35 or 235/40... with 315/30 on the rears. 18". The change from 8.5 to 9 was a no brainer.
  #189
Old 04-26-2012, 07:04 PM
johnspeed's Avatar
I am switching to 295/35/18 rears and 245/40/18 fronts tomorrow,Conti DWs are a great price..And I like the bigger side wall and higher ride height...Chicago streets arent the best..
Thats only a .4'' diameter difference..I ran .5" difference for 22,000+ miles with ZERO diff. problems,And routine tech inspections....
  #190
Old 04-26-2012, 07:08 PM
BOOSTTT's Avatar
BOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to behold
295 30 19 and I fit on some 245 35 19's on front by a millimeter or two. Still no rub! Only one rotation/mile more than stock with that set-up on Hankook evos. Not a hint of PSM light anymore! Feel good too.
  #191
Old 04-26-2012, 08:02 PM
ek9max's Avatar
ek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud of
what about 245/35/19 and 305/30/19?
And What if I have a 12" rear wheel? I have 997 GT3 wheels....
  #192
Old 04-26-2012, 08:05 PM
is there a wider comparable diameter tire for 19"? I'd go wider up front in a heartbeat as long as the diff holds out!
  #193
Old 04-26-2012, 08:25 PM
to answer my own question...I was looking at the size specs and this is what I'm seeing...
stock: 225/40/18, 295/30/19 with a 3 rotation per mile variance.
current: 235/35/19, 305/30/19 with a 25 rotation per mile variance.
possible solution: keep my back MPSS and replace the front with 265/35/19 which is the same diameter as the rears and only has a 2 rotation per mile variance.
now...is that front tire going to be too wide? TR says the approved rim width is 9-10.5
is anyone running wider than 9" up front without rolling fenders?
  #194
Old 04-27-2012, 12:29 AM
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
225/40/19 is better match with 305/30/19 than 245/35 unless you can fit 265/35 in front or find a set of 315/25/19 in rear. Why? Please read the following posted by Thale and pwdrhound:
https://www.6speedonline.com/forums/...rubbing-4.html
  #195
Old 04-27-2012, 09:24 AM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
I'm pretty sure he was referring to those running the 305/30 size in the rear. The sizes you are running are fine. The only problem with your size is tire choice right now. If you can even find them in stock, there are like two options.
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
Quick Reply: Front Differential Chewed due to incorrect wheel/tire se up
