My P-box 200-300s' journey from flashed K16 to SG K16/24 to Proto K24/18g
Good see you doing well in the Proto 18G
2001 996TT 3.6L and stock ECU
Nice time, bro!
I would be VERY CAREFUL running 1.45 bar on pump gas, though. I only run 1.0 bar on pump gas, and I believe others here with this setup do about the same. If you don't have fuel injectors, it's VERY dangerous running boost that high, and even if you do have injectors, I'd be careful. There was 2 members here who have blown their engine running high boost with pump gas, so PLEASE be careful.
Congrats on the new kit. The 18g's are a great setup!!
For stock K 16 or K16/24, they are almost the same when you first push it. K16 run out of feeling very soon. K16/24 last a bit longer, it's good for 2nd, 3rd & 4th gears of tip but slow down at 5th.
K24/18gs are a totally different story. It's brutal all the way. I saw PSM flashed at 3rd gear from time to time if I forgot to turn it off. Frankly, you don't need full gas when you cruise at highway. You can take over 99.99% of the cars if you want to. The K24/18g tip one is a very friendly daily drive car but can also become a beast anytime anywhere you want it to be.
Negative side? It can become an addiction, the seeking of power is never stop.
Did I mention the torque converter? The factory one was gone due to K16/24. It's a must for a tip if you want to push harder from K24/18gs.
Nice time, bro!
Chenshan
Time ............RPM...................... Engine load........................ Actual engine torque ........................Mass air flow (HFM) ......................Intake air temperature ...........................Engine compartment temperature .................Exhaust temp. after cat. conv............. Ignition angle ....................Oxygen sensing, bank 1 ..................Lambda Value........Throttle position sensor 1.................. Vehicle speed ....................Boost pressure of Sensor
02:52:01.8347424............................1605.............................42.44.................... 26.17.................................100.............. 42.8.............62.3....... 235......... 35.25.............. 0.92................. 1.03............ 17........................... 1008.47
I forgot to mention. I did the fully RWD conversion. No error code occured. Car felt more senstive then ever.The first time I felt I controled it, not been controled.
PS. turn the PSM off ^^
Chenshan,
what excactly do you check with these values? I do not think there are info that will help you to figure out how pump gas works with 1,4bar...
knock detection/correction/adaption would be more helpful?!!
edit:
do you run with an external BC?
edit:
I did monitoring all the info I can like knock detection/correction/adaption by PIWIS in the first beginning. I try to increase the boost value little by little to see how it works. All I can say is so far so good. I don't recommend others doing the same thing like I do. I know it is dangerous but I am willing to take my own chance. I bought a set of forged connecting rods long time ago.
I run my boost with Greddy Prof B if this is the "external BC" you refer to.
Chenshan
