Air fuel Meter/gauge
Old 11-03-2008, 08:22 PM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
So now i need to by a gauge to make sure everything is perfect and going to hold up.
What A/F gauge are you guys running?
I am looking at the Brockway but is that the right one?
thanks!
Old 11-03-2008, 09:51 PM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
Corey there are lots of options, do a search and you will find lots and lots of setups, see which one you like the best for you car and order it up...its a very cheap way of making sure everything is bang on.here is a quck pick of my Brockway...but you should know this already.....
notice the 14.7........A good tune goes a long way!
Old 11-03-2008, 10:01 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Brockway..cheap easy plug and play
Old 11-03-2008, 10:09 PM
Zippy's Avatar
I did an Autometer Nexus cluster...
Old 11-04-2008, 09:01 AM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
Titan Motorsports Wideband by Innovate Motorsports
$249.00
Old 11-04-2008, 09:24 AM
MBailey's Avatar
I ordered the Durametric program which lets you look at lambdas off the 02 sensors. You can also log a bunch of other data like intake temp, rpm, ect...
Plus you can see over-revs and clear codes.
Old 11-04-2008, 10:27 AM
onelove's Avatar
Doesn't allow you to view the AF easily or on the fly. If you're out on the highway adding boost or at the limits of your fuel supply, you AF gauge will you right away. If you have to have the laptop in the car, log it, review it, it's a few extra steps that don't allow easy checking.
Old 11-04-2008, 11:02 AM
MBailey's Avatar
I just threw the laptop in the car but its probably not as easy as other options but gives alot more info though.
Old 11-04-2008, 11:09 AM
benguss's Avatar
benguss is infamous around these parts
I have Innovate, great color light bar with digits, records hi and lo, but it's been tempermental.
Old 11-04-2008, 01:33 PM
dixie's Avatar
dixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to all
I have the AEM and the Brockway R920
Old 11-04-2008, 01:34 PM
Valley996TT's Avatar
Valley996TT is just really niceValley996TT is just really niceValley996TT is just really niceValley996TT is just really nice
Do you need to monitor a/f ratio for both banks, so need two a/f meters. Or, is monitoring the a/f ratio of one bank sufficient?
Old 11-04-2008, 01:43 PM
dixie's Avatar
You don't need 2 but 2 is always better than 1.
If you can see the A/F from the 2 banks and they are the same you can be sure the engine is running fine..
Old 11-04-2008, 01:46 PM
Also, should you get a narrow-band or wide-band a/f meter? What is the difference between the two as far as what they monitor and the ease/difficulty of installation? Thanks.
Old 11-04-2008, 05:45 PM
kilrgt's Avatar
You can watch both banks with the Brockway, see my pic in this thread, it shows B1 and B2.
Old 11-05-2008, 06:39 AM
WOODTSTER's Avatar
kilrGT,
where did you get the CF backer plates?
MK
Quick Reply: Air fuel Meter/gauge
