Need help with a Dyno question...please.
Old 11-04-2008 | 01:57 PM
wross996TT's Avatar
Is the AWD Dyno Dynamics OK for our cars? Or does the front diff need to be disconnected. TIA
Old 11-04-2008 | 04:27 PM
Prche951's Avatar
https://www.6speedonline.com/forums/...up-tranny.html
have not read it yet, but it might have the answer
Old 11-04-2008 | 04:44 PM
wross996TT's Avatar
Yeah I read it and the answer is unclear.... Kevin says no.
Old 11-04-2008 | 04:50 PM
Prche951's Avatar
I know the subaru guys have to worry about different speeds in their awd's, so there is a dyno in Springs that tunes Subbies. They should be able to do it. But instead we could get a Vbox and use that method to measure hp? Chris and I have talked doing the dyno down his way. There is also an awd dyno off parker road somewhere
Old 11-04-2008 | 05:21 PM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
Here's a link to some specs. Says it will do viscous-coupled AWD but I can't find any mention of the drums being linked which is what you really need to know.
http://www.dyno.com.au/dyno/controll...owAWD450DSPage
Old 11-04-2008 | 05:39 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Front diff has to be disconnected, from experience.
Old 11-04-2008 | 06:38 PM
WOODTSTER's Avatar
Artiza,
what was your experience?
I specifically sought out a AWD Mustang becuase of mechanical linking that I heard
was critical. This is only what I had heard to be 100% sure. AWD Mustang reads fairly
low as compared to 2WD dynojet (obviously). AWD DynaPack like Kevin (UMW) and
Protomotive have also obviously works.
MK
MK
Old 11-04-2008 | 07:16 PM
art4iza's Avatar
Here is my experience with Dynos ranked in most conservative.
dyno dynamics, mustang dyno, dyno jet or dyno pak. Dyno dynamics generally shows less 90HP than dyno jet and 50-60Hp less than mustang dyno. Based on my experience, we will see how she performs this saturday at 1/4 mile, my proto set up is completed.
Old 11-12-2009 | 11:41 PM
Prche951's Avatar
update on DynoDynamics. The dyno shop claims that the drums are linked electronically and will rotate at exactly the same speed. Should this not be sufficient. One member has several pulls on this dyno with a 996tt, with no apparent problems that I know of.
can anyone say if the DD with electronic link for and aft is good for our cars.
Old 11-13-2009 | 09:07 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Is this the DD in boulder at the Subaru place?
Old 11-14-2009 | 05:15 PM
Prche951's Avatar
I have heard of that one, but it is the one in colorado springs.
Old 11-14-2009 | 05:22 PM
wross996TT's Avatar
Dennis, you were at the one in Boulder and no...that one can not be run without disconnecting the front diff..(and none of us wanted to chance it...LOL).
Old 11-14-2009 | 05:29 PM
Tony@epl's Avatar
Thats my recommendation on any dyno with out linked rollers.
I often uses the DD in boulder. Very nice people there.
Old 11-14-2009 | 06:03 PM
heavychevy's Avatar
Too many questions with DD. I tried one and was told the drums were linked, however when we started off at 15 mph the rear was spinning and the front barely twitching, so we took it off. I wouldnt risk it.
Old 11-14-2009 | 06:18 PM
vbmw335's Avatar
vbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant future
I have dynoed my car several times on a AWD Dynodynamics without disconnecting the front diff. I found it to be the lowest reading dyno for sure.
Quick Reply: Need help with a Dyno question...please.
