Tire Sizing for 996tt. Toyo r 888 ?
Old 11-06-2008, 09:18 PM
porschenaround's Avatar
porschenaround is a glorious beacon of lightporschenaround is a glorious beacon of lightporschenaround is a glorious beacon of lightporschenaround is a glorious beacon of lightporschenaround is a glorious beacon of light
zippy do you have any closer pics of the rims and tires ? also, what size rims are those ?
Old 11-07-2008, 12:08 PM
tom kerr's Avatar
for performance the less the side wall the stiffer so the better on the track for handling less side wall flex.
also worse ride (who cares)
as the tire widens the profile must decrease to maintain constant diameter.
in the RWD set up you dont need to match front to rear diameters then can be a little off.
Zippy is the big tire guru that taught me. I now run 275 front and 335 rear with no rubbing. but remember these size tires are a track set up with -3 degrees of camber no something you would run around on the street with.
the size recommended above is correct.
Old 11-07-2008, 10:34 PM
Zippy's Avatar
Sure. Here's a picture that gives you a pretty good idea about how they tuck in. Rear fenders need to be rolled. Rear plastic inner fender liners need to be reshaped a bit with a heat gun. Front and rear -camber should be no more a minimum of -1.4'. Wheel size is GT2 spec.
Tom, as far as me being the fat tire guy, I actually was coached by Alex (Sharky). I bought the wheel/tire set from him. He gave me the pointers for getting them to fit.
Good Luck!
Old 11-07-2008, 10:38 PM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
Good Luck!
mmmm look at that ep under there!
Old 11-07-2008, 10:44 PM
Zippy's Avatar
Here you go!
wow, thats a lot of rubber there. okay, i decided to go with 315/30/18 and 245/40/18
Any chance of that rubbing ? should i just stick with the 235/40/18 ? i really wanted to try to get a touch more grib from the fronts. . .
Old 11-07-2008, 10:52 PM
Zippy's Avatar
Do the outer diameters of the 315 and 235 match up well?
Old 01-10-2009, 10:37 AM
Guy's Avatar
Guy
Guy is offline
Guy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant future
Zippy,
What size wheels are you running for the 275/335 combo? I'm trying to upgrade my GT2 tyre sizes.
thks
Guy
Old 01-15-2009, 02:45 AM
Zippy's Avatar
Originally Posted by Guy
Zippy,
thks
Guy
The 245/335 combo fit on GT2 spec BBS Racing Wheels.
ModBargains
Audi Vendor Classifieds
09-01-2015 05:26 PM
albert@velosdesignwerks
Lamborghini
08-20-2015 10:15 PM
ModBargains
08-20-2015 12:28 PM
08-19-2015 06:35 PM
Wheel Experts
American Muscle
08-19-2015 09:07 AM
Quick Reply: Tire Sizing for 996tt. Toyo r 888 ?
