removing door sills?
Old 09-10-2003 | 08:19 AM
20C4S's Avatar
want to replace the stock one to carbon fiber. how do i remove the old one without damage the paint?
any pics with "turbo" script?
Old 09-10-2003 | 08:32 AM
PorschePhd's Avatar
It isn't easy. You will destroy the old ones getting them of. I suggest starting and edge and pulling them gently and evenly until it is off. You are going to need some grease and wax remover as the old tape will still be attached. This simply takes time and elbow grease to get off. You will want to pull the lower half of the door seal up to access the whole sill.
Old 09-10-2003 | 08:45 AM
20C4S's Avatar
sounds pretty scary already... do or not do...
Old 09-10-2003 | 08:47 AM
Gary (Fl)'s Avatar
The Newest "Bling King"
Gary (Fl) is infamous around these parts
As Stephen said it takes some time and effort. I pulled up all the edges exposing the tape and then soaked it with solvent to cut the glue. Then I took off what I could and used a plastic putty knife to scrape off the remaining glue. Take your time and soak them, let them sit for a while then work on a section. Then repeat the process until they are all off. It does take time as mentioned, but they will come off clean. I have heard of some using a hair dryer to heat them up and pulling them off but I used the other method. Obviously you will have to wax the areas around the sills as the solvent will remove the wax where it drips.
Good Luck
Old 09-10-2003 | 09:01 AM
20C4S's Avatar
Gary,
any pics?
Old 09-10-2003 | 09:05 AM
Gary (Fl)'s Avatar
Originally posted by 20C4S
Gary,
any pics?
I will have to take a few.. I need to take new pictures this weekend anyway since I added the TechArt Kit and will be sure to take one or two of the sills.
Old 09-10-2003 | 09:10 AM
Jack(LA)'s Avatar
Moderator
Jack(LA) is infamous around these parts
any pics?
Per your request....
Old 09-10-2003 | 10:58 AM
20C4S's Avatar
wow, that "turbo" lettering is big. too big for my taste
Old 09-11-2003 | 11:18 AM
Arnie's Avatar
Arnie is infamous around these parts
Use dental floss. Then clean the residue with a solvent
Old 09-11-2003 | 12:53 PM
20C4S's Avatar
03 C4S,
i'll do it after u
Old 09-11-2003 | 12:59 PM
20C4S's Avatar
Old 09-11-2003 | 01:05 PM
20C4S's Avatar
no. that was on my C4S. i want to get the carbon one for my Turbo.
Old 09-11-2003 | 01:09 PM
20C4S's Avatar
i haven't order them yet. still thinking should i get them or not.
the "turbo" lettering is really too big for my taste.
Old 09-11-2003 | 02:21 PM
Gary (Fl)'s Avatar
You need to see them on a car to get the proper prespective. The lettering is large, but it appears larger in a photo of only the sill. I think you will like them once installed. I have had nothing but positive comments and the "I have to get those" statements.
Just a comment, I would have never been able to get mine off with dental floss.. It would not have been strong enough. It took much force to pull them off after soaking them with solvent.
Old 09-11-2003 | 06:46 PM
20C4S's Avatar
so the solvent won't damage the paint at all?
Quick Reply: removing door sills?
