Leaking In - Front Footwells
2003 996tt
I seem to be having a problem with water getting into the vehicle, both front footwells are wet.
I've checked the drain holes under the hood underneath the scuttle panel and cleaned them out, I also have a quick look at the front bulk head to see if there were any grommets not fit correctly. I've also pulled the door panels off to check that the door is sealed up without any rips.
Is there any other common places where these leak water in??
Have it in my garage at the moment stripped down and a heater blower drying her out.
Any help in tacking down this leak greatly appreciated
Cheers
Westy
Cheers
Westy
2003 996tt
Cheers
Westy
Cheers
Westy
Is it wet under the carpet (behind the pedals) on the firewall or can you see water marks like if it was coming in from under the wiper area and down the firewall?
Anywhere else these things rain in??
Checked.
1. Drain Holes
2. Door Panels
3. Door Seals fitted correctly
stevenrmusic
Bentley
17
11-12-2015 05:53 PM
