Clutch Question - feel rougher
Old 11-10-2008 | 01:25 PM
SilverTTCab's Avatar
Senior Member
SilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud of
i have a 04 turbo with 25k miles
the clutch is harder to press down before starting the car, and feels like it's catching a bit on the way down.. like arthritis (my knees anyway)
there's no issue with slipping when i'm out driving, but i was wondering if that's what's next.
how long are these clutches supposed to last anyway?
i drive it mostly on the weekends for fun, and it's never been on the track.
any thoughts and comments would be appreciated
Old 11-10-2008 | 01:45 PM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
Sounds like accumulator or slave, is it making any noise?
Old 11-10-2008 | 03:09 PM
wross996TT's Avatar
+1 ^ accumulator....
Old 11-10-2008 | 03:51 PM
OCTurbo's Avatar
OCTurbo is infamous around these parts
just had the same problem. it was the clutch accumulator and slave.
Old 11-10-2008 | 04:25 PM
Senior Member
oh.
never heard of an accumulator and slave lol
how much to fix?
Old 11-10-2008 | 04:27 PM
Senior Member
no noise out of the ordinary...
common problem at 25k miles?
Old 11-10-2008 | 05:07 PM
VAGscum's Avatar
This may be a stupid question, but did you check your accumulator level?
Old 11-10-2008 | 08:30 PM
josh@iautohaus's Avatar
josh@iautohaus is a jewel in the roughjosh@iautohaus is a jewel in the roughjosh@iautohaus is a jewel in the rough
Sounds like an accumulator to me. Early signs of an accumulator failing is hard pedal when starting up and then back to normal after the car is up and running. What happens is the accumulator after sitting a while it will internally bleed down its pressure and that is why you have a stiff pedal start up bc there is no hydraulic assist. A lot of shops will charge you the labor time to get the slave out too, but the accumulator can be sneaked out.
Old 11-11-2008 | 12:06 AM
chucky0431's Avatar
chucky0431 is infamous around these parts
I just came from the same problem, here is a thread I had going on
https://www.6speedonline.com/forums/...-new-post.html
also an 04 but with 17k.
Good luck with it, 3 hour job, but its worth it.
04-28-2022 01:38 AM
COBB Tuning
01-29-2022 10:42 AM
gulf gt
08-27-2015 11:27 AM
albert@velosdesignwerks
Ferrari
08-22-2015 10:31 AM
