K24/k26 technical quandry
So as you may have read on my other lengthy thread, I was recently forced to replace both of the turbos on my TTS. I elected to buy a used set of k24/k26 turbos from YllwTurbo, who has been a real pleasure to deal with and told me that if there were any problems with the turbos he would take them back. Great guy.
As my mechanic was getting ready to install them today, he noticed that the hot-housing looked a little small. It turns out that these turbos have k16 hot-side housings machined out to accomodate k24 wheels. So they are (in my understanding) not technically k24/k26 turbos. My question is - what is the downside of running this setup? I am told that this might result in superior spool up times with some sacrifice on the top end. On the flip side, it seems crazy to put k16 anything on an Turbo S (X50) car that came with k24 turbos.
Am I wasting my time here, or is this something to be concerned about? I know that YllwTurbo will take them back if needed, but I'm not sure whether that is necessary. Can I get someone's expert opinion on this issue?
So this is your second set of Fake K24/26.. If that is the case, someone in LA is fabrication and selling fake turbochargers and passing them off as K24/26. The K16 turbine housing is similar to the K24 housing and many folks cannot tell them apart. The fake sets that I have seen have a clipped wheel installed into a K16 housing.
If it doesn't have the K24 turbine housing, get your money back.
2001 996TT 3.6L and stock ECU
I bought a used FVD kit that included a set of "Stage 3" FVD "race" turbos and they turned out to be regular old K24's. Sent them to Blouch for an 18G wheel and waste gates...
My understanding is that a true k24/k26 turbo would be a cold side k26 housing and wheel, combined with a hot side k24 housing and wheel.
You can see that I am only just beginning to really understand this. Right now I am inclined to take Kevin's advice and go back to a stock k24 turbo.
These programs ( when done right) do adjust and I have seen same maps run on different turbos just fine...
I may be wrong here, but these things aren't like pipe fittings or legos!
The 'words' of what these are must be supported by sklled fabrication. Just knowing it is a "K26/K24" is a small part- what matters is the inherent quality of the parts and the assembly.
It is just ASTONISHING that people buy these unknown parts and slap them into a $20k motor.... and wonder why dynos are screwy.
Then again, maybe turbos ARE like tinker toys and fabrication isn't a factor in how they compare.....
A
A
Oak
Wayne,
What turbos are you currently using and what programming?
MK
ModBargains
Bentley Vendor Classifieds
10-13-2015 03:42 PM
ModBargains
Lotus Vendor Classifieds
10-13-2015 03:42 PM
ModBargains
McLaren Vendor Classifieds
10-13-2015 03:41 PM
ModBargains
10-13-2015 03:40 PM
10-06-2015 06:13 PM
