1st time at the ¼ mile track with the 996TT
So I went down to Englishtown for Sunday's test and tune. There was a special event going on: "over-crowded day". It took me an hour to get through tech and then it was 3 hours between runs (atleast the car cooled down a lot between runs). I only got in 2 runs, which was enough to learn how bad I suck. The weather was 60 and muggy.
My car: EPL custom tune, K16/16g hybrids, DGI Exhaust (I forgot and left the 5mm reducer rings in), Clutchmasters Kevlar clutch, Summitomo tires at 40psi, ½ tank of 93 octane, full weight.
Run 1:
Launched at 2,800rpm, cut a 2 sec 60 foot, banged the rev limiter in 3rd.
Apparently someone in the stands filmed it and put it on youtube (my buddy sent me the link):
[video]
Run 2:
I ran against LiNkS from the board. He's got a tuned K24 car and there's a fuller description of his setup here:
https://www.6speedonline.com/forums/...ge-faster.html
He was running ½ and ½ 93 octane and race gas. I tried pulling the fuse to the wing to see if less drag helped.
We both have the same clutch and tried to launch at 4,000rpm. Consequently we wheel hopped and spun through all of 1st and most of 2nd. I did pick up 1mph, though.
No video this time. Here's the slip (I'm on the right):
So after 2 runs, my best ET was 11.96 and best trap was 123.96.
All in all, I think there's a lot still left in there and I'm definitely going to try some race gas next time. Also, we need to do a track rental because 3 hrs between runs is misery.
Run 1:
[video]
Run 2:
whats your sustained boost....
2001 996TT 3.6L and stock ECU
That day was one of the worst experiences at the track I have ever had. We definitely need to do it again on better circumstances. I am just happy my car trapped at that speed. All in all it was nice meeting you out there, at least we got to crack a few jokes..... are you going to be at the Turkey Run this weekend?
Good, time and good speed IMO. interesting that the K16 and K24 ran close trap speeds. it would be interesting with you running the same fuel.
I dont think my tires hooked up until after the 1/8 mark I spun through 1st, 2nd (which i had to completely let off cause the rear end starting coming around) and even chirped into 3rd.
Shameless plug: We have k16/16g kits in stock and ready to ship .
Can't make the turkey run, but I'll probably be at the next ER run.
There's only 2 weeks left at E-town, and to tell you the truth, if last Sunday was any indication, I'll pass. I'm going to wait until a track rental. There's something about 30 passes vs. 2 passes that makes more sense to me.
