Good or not? dyno result
Art
I dynoed my 996 TT with same turbos as yours/ ECU flash and a PSI exhaust. I got 439 rwhp on a dyno dynamics, so the range is about right.
FWIW, almost a year later I went back with straight pipes which hurt the low end power a little, and DV's which helpd more than the straight pipes hurt and dynoed 523 rwhp on a dynojet. I think with the PSI exhaust it would have hit 530 rwhp.
I wouldnt worry, you are in the ballpark, but GET SOME DV's. Maybe a drag strip run or two with a baby launch so as not to wheel hop. Your car should trap 122-127 depending on what kind of conditions you have.
DV's are next, I want something the dealer will not pick up on, Bosch do an uprated one right?
If I trap the figure you are talking about, how many seconds will I run? roughly.
Lee
I have seen, on the cars readout, .9 bar at about 7000' altitude on my 05
Turbo S with 70mm Speedtech.
RD
Maybe Jimmer can help you out, he seems to be really good at drag racing.
I'm not that good at the drag strip so I cant offer any techniques. But my best time prior to DV's and in a full weight TT weighing almost 3800 lbs with me in it was a 11.71 @ 124 and my best trap was 125 mph. And that was with a 2.0 60'.
A general rule of thumb is that .1 faster in the 60' equals .2-.3 faster at the end. So had I got a 1.8 60' I should have been 11.3-11.4.
Hope that helps.
I am more surprised that they are BOUGHT without knowing what is there.
(of course we are saying the same thing)
Given the potential for some tunes to cause engine destruction- why would you troubleshoot around an unknown DME and build your mods on top of an unknown foundation?
nick49
08-28-2015 01:40 PM
