Intake Piping?
#31
Maybe this helps. Remember that the intake piping most often referred to is the pre turbo piping. This helps the turbos draw in more air with less static pressure and thus a bit lower heat. Once the turbos boost the air yes it can force a bunch through even smaller pipes through intercooler and y pipe. The bigger pipes are pre boost. Once you are REALLY boosting with huge turbos then bigger piping all the way is probably better. I am no engineer but this is how I understand it.
#32
we did a test on a 20g set up with and without biugger pipes... and all I can say is that the 20gs without the pipes were laggy... once we put the pipes in the car woke up....
2001 996TT 3.6L and stock ECU
#33
Mark - are you referring to the intake pipes before the turbos?
Or the Proto intake with a bigger Y-pipe?
(btw thanks for putting up with all the PMs i've been sending - and thanks for the emails you've sen too, very interesting!!!)
#34
this is true!! i have first hand experience the 20g's do not work with stock air inlet piping
#37
im running the 2.5 inch pipe... and yes it spools quicker and reaches full boost quicker!
#39
yes running the full proto minus the intercoolers... bell is building me a set of ic's right now... with the proto inlet pipes you have to run the proto y-pipe to accomodate the blow thru maf
#41
[quote=cjv;2142421]ant,
We started with the stock TB and bored it a few mm's. Don't hold me to the numbers because it has been a long time. I think they were around 66 mm, plus the bore. Then we went to the GT3 TB and I believe they were around 74-76 mm. We finally settled on a 90 mm TB. END QUOTE
Where did the 90mm TB come from? What is it?
What HP level would this come in to play compared to 75MM?
What is the downside of such a size TB?
#43
Are you running stock intercoolers at the moment Tim?
If so what have you done about the location of the DVs
Will this change when the new intercoolers are installed?
#45
right now im running tock ic's bell is building me some custom 4.5 inch core with 2.5 inch inlet outlets no the DV's are on the legs of the y-pipe and thats where they will stay
