will 255/40/18s with spacers rub?
First check that the RPM is within 3% of front and rear tires. If its okay then, i would say it will be a very tight fit.
I had 255/35/18 that fitted perfectly. The sidwall was smaller so it fitted fine, but your staying with 40 which may cause some rubbing.
I have a set of 255/35 18s as well. Fits great with either the 8" stock front or 8.5" GT2. Actually is a great setup due to increased width (less understeer). 255/40 18s are to tall and may burn up your viscous coupling.
Boldgt
03-23-2016 11:07 AM
Pcar991
09-29-2015 05:20 AM
