I've Just Flatspotted My Tires
Old 11-25-2008 | 12:09 PM
speedwerks's Avatar
speedwerks is infamous around these partsspeedwerks is infamous around these parts
Originally Posted by ant_8u
The rear tires are slightly worse than the fronts are, but the fronts could do with a little attention too
Would a burn out work on the front tires or not?
I'm guessing I wouldn't be able to get them spinning?
PSM off, and roll through a puddle of water, or start in a small puddle of water.
Old 11-25-2008 | 01:56 PM
WyattTT's Avatar
WyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud of
Originally Posted by Sker66
Anyone know of any shops in Orange County california that does shaveing??
Try the off-road/4x4 shops. Not uncommon to shave the large tires to get them to balance. Good luck to you
Old 11-26-2008 | 03:45 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
I like your thinking!
What's the best approach for burn-outs? - I've not done them before
(i know - i haven't lived!!)
What revs should I be at for best effect?
And would donuts be better than a straight line burn-out?
Old 11-26-2008 | 07:34 PM
LT1's Avatar
LT1
LT1 is infamous around these parts
Hose down enough road to roll through to get all four wet then punch it with traction control off. If it spins nice in 1st gear, try again starting in second with perhaps more revs and a clutch pop. Make sure you choose a real nice smooth road surface. Oh, make sure you mask off any wheel wells/exposed paint you don't want sandblasted.
Old 11-26-2008 | 07:59 PM
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
So.. If you're MAF is having issues, will you have ABS issues as well? The reason I ask, is because I've been sliding tires at slow speed, and having idle issues.
I've never had the issue you have, but if you need some tires that are descent and $750 shipped for all four, check out Sumitomo's @ Tirerack.com. I'd try ol' Steve-O's advice first
danyoP4S
09-30-2021 05:06 AM
WheelB
991 Turbo Vendor Classifieds
07-23-2018 09:37 PM
oo7
09-10-2015 08:08 AM
WheelB
09-03-2015 10:26 AM
gabe325
911
09-02-2015 08:10 PM
Quick Reply: I've Just Flatspotted My Tires
