Thoughts on the next upgrade
Old 11-23-2008 | 06:13 PM
Christian's Avatar
Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !
Let me know what you guys would do if your car had the following:
24/18g's w/wg's
Softronic Tune
SpeedTech Exhaust
Ported OEM Headers
Bailey DV's
5 Bar FPR
AP Airbox
RWD Conversion
Sachs Stg 3 Clutch
I am definately doing the injectors and fuel pump, so list anything else that is worth doing your opinions
Old 11-23-2008 | 06:39 PM
unvmy996's Avatar
Christian i would do injectors as you said .to bad you have the ap air box , i would save up and get the proto intake system Y pipe and all .and convert to a blow through setup.
Old 11-23-2008 | 06:47 PM
tom kerr's Avatar
24/18g's w/wg's
Softronic Tune
SpeedTech Exhaust
Ported OEM Headers
Bailey DV's
AP Airbox
RWD Conversion
Sachs Stg 3 Clutch
would help Christian if we knew what you wanted to do with the car? just fun on the street, drag race, or road race? My car is set up similar to yours. I dont see a 5bar fuel pressure regulator? that may be all you need for the set up you have. Also have you not done anything to the suspension? cause that is a must with your car. also dont see a mention of brake upgrades? also a must. if you have done those your car is similar to mine. I track my car and at Daytona near 200mph really doesnt need anything else other than more downforce and why I went with a bigger splitter and rear wing.
what I would do at that point is a data aquistion system like traqmate and professional driving lessons. I am relating to you what I have done, FWIW.
good luck
tom
Old 11-23-2008 | 07:07 PM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
You're in the same boat I am, and we have almost identical setups.
You really need intercoolers now with your current setup, so I would do those before you go any further. Silicone boost hoses are also a good idea. I would also add a boost controller. After that, you're going to have to upgrade the fuel system, since you have the OEM system maxed out. Intake pipes would be good to let the turbos breathe easier. A larger y-pipe, throttle body, and y-plenum will open up the intake and offer less restriction.
After that...I don't know....maybe GT30's
Let me know what you end up doing, and how you like it. I'm looking for suggestions.
Good luck!!
Old 11-23-2008 | 07:16 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Christian
This is what I recommend... add another bosch 044, 60 lb injectors and larger lines and your car will make 800 RWHP. I had a very similar setup once upon a time. I hope this helps and yes a boost controller is very important at these HP levels.
Good luck
Robert
Old 11-23-2008 | 07:32 PM
Good luck!!
let me know when ur ready... Ill set you up with a set up that will blow the doors off what you currently have...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 11-23-2008 | 07:39 PM
Details, please! I'm interested...you can PM me if you want.
Old 11-23-2008 | 07:57 PM
unvmy996's Avatar
In due time
Old 11-23-2008 | 08:45 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Originally Posted by robmd99
Christian
Good luck
Robert
Umm - he might need a engine build before he does that Rob LOL
Old 11-23-2008 | 09:12 PM
colorinc's Avatar
colorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond repute
your car is set up real well... are you running stock internals?
Old 11-27-2008 | 05:52 PM
Christian's Avatar
^Yes^
Christian
Old 11-27-2008 | 06:19 PM
Mikelly's Avatar
I'd start saving money...
...For a motor build.
700BHP is what i've always been told is the "limit". I'd suspect you're there...
Mike
Old 11-28-2008 | 01:05 AM
ard's Avatar
ard
Suspension I would say.
I find that the increased power really pushes the stock suspension to it's limits...hard. Planning on JIC.
A
Old 11-28-2008 | 06:31 AM
Mikelly's Avatar
...Along with motor and tranny mounts... That drivetrain is mounted with lots of freedom to move around and porpous. Enough to cause your tips on your exhaust to hit the rear valance...
Mike
Old 11-28-2008 | 07:26 AM
silvershark's Avatar
silvershark is infamous around these parts
Question Motor & Tranny Mounts
Mike,
Do you recommend changing the mounts? If so, which ones?
Thanks, Joe
