996TT max speed?
996TT max speed?
As I have posted before, I will be going to Germany to live/work in less than a month and shortly thereafter will be acquiring a stock US-Spec 996TT. I know the top speed for a stock turbo is 192 mph but could it hit 200+ mph after being flashed with no other mods? Cheers.
If the flash raised the redline you might be able to come closer to 200mph. I dont know if a flash would give you enought HP to make it to 200 though.
I think 192 is at the stock redline in 6th gear.
189 mph stock redline (6750) with stock tire circumference.
It takes alot more power than you think to cut through the wind at 200 mph
(and alot more TIME if you are not 700 HP+)
Good luck!
MK
Good luck!
MK
have a video doing 326kms on stock k16s with flash Dv's exhasut and short throw shifter. Car felt good, had a bit more i think...but I ran out of road....
I would think that your speedometer is more correct at high speed. I believe the PB takes snapshots 10 times/sec. When you go faster, 10 times may not be enough. just IMO.
Porsche speedos almost always read high. I have tested several cars with both P Box and a hand held radar. Both say 2-3mph faster on the speedo than the measuring device at normal speeds. I think the error increases with higher speeds.
I can confirm, but will not release GPS data that shows 205.4mph top speed of a UMW K16/24 combo with UMW wastegate springs and 5 bar FPR.
I believe the car had more in it, but according to the data and the driver the road conditions were rapidly changing and the driver had to reduce speed.
Mike
Mike
Mike
Mike
Did the car have stock wheels and redline?
