996TT 3.8 pistons
996TT 3.8 pistons
the guys that have tried the 3.8 combination with your 996tt and had problems, do you know what mfg. of pistons and cylinder liners they used? any help would be appreciated. Thanks Greg
Call BBi autosport in Huntington Beach. 714-843-0200, ask for Betim.
Art
Art
Skarkster, Stay as far away as you can from Woosner that's for sure. If you hear the words "plasma coated liners" run... run as far as you can.
thanks, Alex
No worries and best of luck. Find a tuner/engine builder first and see what he/she has used before. You want a proven set up. You don't want to be the "R&D" project for someone either... Going 3.8L isn't as easy as it sounds unfortunately.. Figure out the compression ratio you want to use as well because that can help make your decision on what other parts/Turbos etc.. to go with. Looking back on my build I probably wish I hadn't gone as low as I had because of the lag but then again I knew I'd be using crap gas most of the time;(
I have probably the most powerful 996 3.8 turbo? I have 6000 miles on this motor without any problems! NO PROBLEMS! My car is tuned by Protomotive and built by Noble Performance (Akram) here in the Rocket City. You can PM if you like...
Happy Holidays
Robert
Happy Holidays
Robert
I think Rob has a good engine with 6000 miles. He probably has more experience having one. BBi just finished a 996TT with a 3.8L engine and I drove in it. The redline was awesome at 8500rpm. These guys are from Porsche motorsports team and porsche lemans team. You make the decision and I am not here to tell anyone what to do. Best of luck.
Art
Art
mahle
yes, that is what we are looking at I just wanted to make sure that the problems posted were not with the Mahle parts. they look great. thanks Jean
CP Pistons make pistons and you can get great steel liners from Neil at Performance Developments.
I have a spare set of 102 mm pistons if you are interested. I have had just about every manufacturer of 102 mm pistons made. I'm now using 105.7 mm pistons.
Also be aware that many people sell 102 mm pistons as a 3.8 displacement. They are not. With a standard crank throw that is under 3.8L displacement. They just round out to 3.8L. You can get the correct size to get a true 3.8 displacement and have your liners honed accordingly.
![](http://i251.photobucket.com/albums/gg295/cjv996tt/IMG_5174-1.jpg)
![](http://i251.photobucket.com/albums/gg295/cjv996tt/Viso062105-02.jpg)
